pushrod length????
Old Nov 6, 2005 | 04:34 PM
hoogabooga's Avatar
Car: '68 corvette '73 Corvette
Engine: 427 454
Transmission: TH400
pushrod length????
I am going to get a set of K.D. trick flow heads for my G.W. 350 with some Comp magnum roller rockers and a crane 228/228 .480/.480 cam. It says i need special length pushrods with these heads.
http://store.summitracing.com/defaul...=egnsearch.asp
does anyone know exactly what length?
Is this the best head coice for $1200?
How will that cam idle?
What is cnc porting?
thanks for any info.
Old Nov 6, 2005 | 04:42 PM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Transmission: TH-350C
Axle/Gears: 3.43
grab a rod length checker, then you will know 100% which ones are right.
I would spend a few extra dollars and get some AFR heads, but i hear their is a bit of a wait to get them.
Old Nov 6, 2005 | 05:16 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
You can't "guess" at the pushrod length. There are too many things that can change the length required. Cam base circle, deck height, valve location in head, valve length can all change the required length.
The only proper way to know what length pushrod your engine requires is with a pushrod length checker. Very rarely will it be shorter than stock. Buy a length checker that the bottom measurment starts at the factory stock length.
wigmobile
Feb 26, 2025 02:56 PM
manualbrakes.com
Brakes
63
Apr 9, 2024 11:55 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
mfp189
Sep 27, 2015 09:25 AM
Scorched1984
Sep 15, 2015 03:42 PM
