Hyd roller camshaft question
Old Nov 7, 2005 | 06:16 AM
flyin89's Avatar
Ok heres the deal I got a 96 vortec block with powder metal rods
windage tray the works. I want to run a 540 lift camshaft but I have read that the lifter bottoms against the little plates the
spyder holds down if you go over 520 lift. Anyone went over
520 lift with the stock hyd roller set-up? Any help would be greatly
appreciated.
The rest of the motor will be 2304 pistons and alum heads so yes I really need that much cam.
Old Nov 7, 2005 | 11:43 AM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
I'm running a .560 lift with no probs on stock GM Hyd rollers and setup. You'll be more then fine.
Old Nov 7, 2005 | 12:39 PM
Free Bird's Avatar
Car: 91 GTA and 85 IROC
Engine: 355
Transmission: gear jammer
Axle/Gears: 4.11
I'm running .576 no issues.
Old Nov 7, 2005 | 12:49 PM
The problem with high lift cams isn't the lifter hitting the retainer from the bottom; it's that the lifters fall out of the retainer.
They don't make cams "bigger" by making the tip of the lobe taller. Standard practice with cams is that the tip of the lobe is made as tall as it can possibly be and still be able to install it (the lobes will just barely go through the cam bearings). Rather, since lift is the difference between the back of the lobe and the tip, you make a cam "bigger" by leaving the tip of the lobe alone right where it is, making the heel of the lobe smaller. That's why you can take a worn-out cam and regrind it - remove material - to both renew it and make it "bigger".
When you increase the lift this way, the lifter sinks so far down in its bore at zero lift, that it can come completely out of the retainer.
That machining on the block is not particularly precise, as factory cams don't come anywhere close to the limit. It doesn't have to be. .575" is about the point at which it starts being a REAL GOOD IDEA to check. If you've ever seen what happens when a roller lifter becomes free to rotate in its bore, you'll check them ALL, every time, regardless of what you think the max lift might be. And, you may very well find that the lift limit is different on different lifters, and especially from one side of the block to the other.
Old Nov 7, 2005 | 12:58 PM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Transmission: TH-350C
Axle/Gears: 3.43
1.6 rockers
Old Nov 7, 2005 | 02:22 PM
REALPOWER's Avatar
Car: 1984 Camaro on steroids/ 1987 iroc-z28 5 speed.
Engine: 383 nitrous motor / poindexter 305
Transmission: Th350
yup, .540 lift and 1.6 rockers here.
that equals about .576
Old Nov 7, 2005 | 03:01 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Very interesting. I always wondered that
Old Nov 7, 2005 | 04:52 PM
Red Devil's Avatar
Car: Tree Huggers
Engine: Do Not
Transmission: Appreciate Me.
Amazing... we have a noob who didn't go to the mcdonald's parking lot to learn the typical monkey spank... And from what I've seen I like his writing style to boot. Reminds me of a cranky old fart that used to post here all the time...
Old Nov 7, 2005 | 06:29 PM
jms's Avatar
jms
Off topic, slightly, but what happened to RB, errr, I mean that cranky old fart?
I really would like to know.
jms
blackroc68
Sep 1, 2015 08:01 PM
midge54
Aug 29, 2015 09:51 PM
SLNTSCPE
Aug 22, 2015 09:15 PM
Dialed_In
Aug 20, 2015 01:45 PM
redmaroz
Aug 16, 2015 11:40 PM
