Engine Books?
Old Nov 9, 2005 | 01:43 PM
Mcdamit's Avatar
Car: 89' Iroc-Z G92
Engine: TPI 305 G92
Axle/Gears: Limited 9 bolt, 3.45
Engine Books?
Anyone Know of any books deeply explaining engine dynamics, I am not refering to turning wrenches. That any monkey can do. I am refering to theory.. I am writing a research paper.. I need 3 books
Old Nov 9, 2005 | 07:56 PM
brutalform's Avatar
David Vizard goes pretty in depth on everything he writes. Try doing a search on him, and Im sure you'll find somthing. Also, John Lingenfelter On Modifying SBC Engines is one that I like.
Old Nov 9, 2005 | 08:51 PM
Streetiron85's Avatar
Car: '85 IROC
Engine: LB9
Transmission: 700 R4
Circle Track magazine contains articles that get quite a bit more technical than the stuff you find in CHP or HR etc.
http://www.circletrack.com/techartic...458/index.html
There might be some interesting reading there, and some good links too.
Old Nov 9, 2005 | 09:36 PM
spedrace35's Avatar
Car: 91 camaro z28
Engine: 6.3L, heads, headers, cam,.....
Transmission: 700-R4 w/shift kit and 3-4 WOT kit
Axle/Gears: 4.11
One of the books that I have read from was "how to build horse power" It was very detailed and went into the dynamics of how the engine operated. I dont have the name of the author right now but I will look for it.
edit: Ok the book I read from, and other books a read in book stores are from publisher SA Design. do a quick search in summit for example and type in books in the search box and then click SD Design. The books are kind of expensive so what I did was I went to a book store sat down, with a pen and paper and took notes. The books are about $15 each. There are so many books to chose from ("how to build a 350 on a budget" to "how to build max performance rat motors" ) so buy the book that interest you most. Well I hope this helps out!!
Kevin91Z
Southern California Area
22
Sep 19, 2022 10:00 AM
z28_AJ
Aug 27, 2015 08:59 PM
Jae992
Aug 27, 2015 09:07 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
Leggman1
Aug 6, 2015 04:15 AM
