explosive coolant at high RPM?!
Old Nov 12, 2005 | 11:17 AM
88_Import_Slaye's Avatar
Car: 88 Camaro
Engine: 310 LG4
Transmission: 700R4 w/2200 stall
When the motor is warmed up and I rev it to a high RPM like 4000-4500, coolant will shoot out from some unknown location. It's NOT a leak anywhere, it's like a cup of coolant. It looks like it might be coming from the water pump intake, but I dont see how since the snout has a lip and it has a hose clamp that is pretty tight.
None of the hoses are leaking or broken, all brand new (this is brand new build btw). It's only at high rpm and it's only like a cup or so, but it doesnt do it all the time. It happened once before, we tried to recreate the problem, but it wouldnt go.
WTF is going on?
Old Nov 12, 2005 | 08:23 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
unless you can rev it, and have it spray up while watching it (huh, not a bright idea actually...) you'll never really know.
you could hook up a coolant tester, basically a handpump pressurizer, pressurize the system and see where/if it leaks.
There's a hole in the top of the water pump, that'll leak when the bearings go I think... is it the old water pump on the new motor?
water pumps are pretty cheap.
Old Nov 12, 2005 | 11:31 PM
PhLaXuS's Avatar
Car: 91 Camaro RS
Engine: 305 TBI
Axle/Gears: 2.73 Posi w/Disc
My bet's on the waterpump. I've had those things go out on several different cars when they get old just by replacing the serpentine belt -- too much tension for the old pump. Could also be a bad radiator car, but I doubt it. I think they're 16lb caps. Could also be some other bizarre thing such as the heater valve is cracked or something like that.
Old Nov 14, 2005 | 09:47 AM
Car: 88 Camaro
Engine: 310 LG4
all parts are brand new. I have new rad cap that is high pressure, it has one of those pressure relief tabs and the coolant overflow is also hooked up. No heater core, goes from rad to pump to rad again, no other components in the system.
Old Nov 14, 2005 | 10:11 AM
PhLaXuS's Avatar
Car: 91 Camaro RS
Engine: 305 TBI
Head plug or coolant sensor/fan switch not installed or all the way?
Old Nov 14, 2005 | 10:30 AM
Car: 88 Camaro
Engine: 310 LG4
there is no fan sensor / switch as of yet, while running the motor, I just give power to the fan by hooking it up to the bat. I havent gotten my dc controller yet.
Also, it's coming from the front of the motor, because it gets all over the front and on both sides, but mostly it gets on the pass side. this is why it's thought to be the water pump hose.
It doesnt leak anywhere else at any temp or RPM, only when it's warm and i rev it high. it's also not a consistant leak. it just sprays out then stops.
Old Nov 14, 2005 | 02:07 PM
sellmanb's Avatar
Car: '86 Berlinetta
This happened to me, but seemingly less severe.
I had bad hose clamps and so my radiator hoses would start to pee out coolant when it was revved (i dont know why it wouldnt do it at lower RPMs). I just got my safety glasses on, turned the car on and throttled the carb and found out where it was. 5 second test and a 10 minute fix .
Hopefully yours will be that easy.
Old Nov 14, 2005 | 04:10 PM
Free Bird's Avatar
Car: 91 GTA and 85 IROC
Engine: 355
Transmission: gear jammer
Axle/Gears: 4.11
Re: explosive coolant at high RPM?!
Obviously it is a leak. Get a friend to watch the motor when you rev it. Or work the throttle by hand as stated above. And don't forget your safety glasses.
Old Nov 14, 2005 | 04:13 PM
PhLaXuS's Avatar
Car: 91 Camaro RS
Engine: 305 TBI
And be friggin careful if the coolant is warm. Third degree burns are very likely.
eightsixseven
Dec 16, 2024 01:50 PM
GTAman
Sep 21, 2015 09:57 AM
Bstrang6
Sep 8, 2015 04:29 PM
Dialed_In
Aug 20, 2015 01:45 PM
