My 305 TBI Pings like crazy
Old Nov 13, 2005 | 02:43 PM
jimp2001's Avatar
Car: Red on Red 89 RS
Engine: LO3 305 TBI
Transmission: TH-700R4
Axle/Gears: 10-bolt / 2.73
I was pinging so I ran 89 octane, it helped a little. Now I run 93, and it pings a tiny tiny tiny tiny bit... most people wouldn't enen notice it.
My timing is only 2* advanced... why does my car ping so much?
According to the manual, the car runs on 87 with a 0* timing.
Old Nov 13, 2005 | 02:47 PM
92lt1's Avatar
Car: 91z
Engine: 350 vortec
Transmission: built 700r4
Axle/Gears: 373
Just a thought....
You might have to much carbon build up causing hot spots. Which in return are causing your premature igniting.
Old Nov 13, 2005 | 04:06 PM
Codename 47's Avatar
Car: 1986 Camaro Z28
Engine: 400
Axle/Gears: 10 bolt Posi 3.73
If you have carbon build up try this stuff.
http://www.sdpc2000.com/catalog/1015...8-cyl-18oz.htm
-Greg
Old Nov 13, 2005 | 06:27 PM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
I like Sea Foam, down the IAC valve bore. Makes it smoke like crazy. Then go blow it out real good.
Old Nov 13, 2005 | 06:46 PM
jimp2001's Avatar
Engine: LO3 305 TBI
I also heard that spraying small amounts of water into the tb while revving the motor cleans out carbon deposits... is that true?
I'm a cheap bastard... saving up for that 4th gen leather interior
Old Nov 13, 2005 | 07:39 PM
PhLaXuS's Avatar
Car: 91 Camaro RS
Engine: 305 TBI
Axle/Gears: 2.73 Posi w/Disc
The water trick sure does work. I slowly dribbled water into the throttle body from a measuring cup. Just bring the engine to 2-3000RPM and go slowly to avoid problems. Misting it in will work as well and is probably more safe than dribbling it in.
Old Aug 18, 2012 | 10:58 PM
bluebird384's Avatar
Re: My 305 TBI Pings like crazy
i have the same problem with my 1994 olds 88 royale , pings and pings on highway , carbon build up ?
Old Aug 19, 2012 | 03:59 AM
paulo57509's Avatar
Car: '87 IROC
Engine: LB9
Transmission: TH700R4
......Or a non-functioning EGR system.
Old Aug 19, 2012 | 04:29 AM
but i have no check engine light on tho for egr
Old Aug 19, 2012 | 04:04 PM
paulo57509's Avatar
Car: '87 IROC
Engine: LB9
The ECU won't set the CEL if the exhaust passages are plugged with carbon.
Old Aug 19, 2012 | 04:26 PM
could you explain what you mean ? the ecu wont set the cel if the exhaust passages are plugged with carbon
Old Aug 19, 2012 | 04:29 PM
i dont ever have a check engine light on , just pings like heck , you can really hear it ping , i put seafoam in gas , i have tried everything , engine doesnt knock tho. possibley engine needs a cleaner put in it ?
Old Aug 19, 2012 | 09:16 PM
paulo57509's Avatar
Car: '87 IROC
Engine: LB9
A small portion of exhaust gas is diverted into the arir/fuel mixture to cool the combustion process. This is done to lower NOx levels as a way to control exhaust emissions. This small portion of exhaust gas is diverted into the intake via the EGR (Exhaust Gas Recirculation) system, which consists of the EGR valve and passages which route exhaust gas into the intake tract.
The only time the ECU will set a code for the EGR is if it senses that the EGR valve isn't opening.
The EGR could still be opening, but if the exhaust passages are plugged, exhaust gases will not get to the combustion chamber to cool the combustion process.
If the combustion process is too hot, you'll get pinging.
If the exhaust passages are plugged, no fuel tank additives or cleaners added to the crankcase will unplug them. The carbon has to be physically removed.
Old Aug 19, 2012 | 11:46 PM
thank you for the advice , about possible exhaust passages are plugged , and carbon has to be physically removed. could a dealer or a cheaper private person be able to remove that carbon , or is this a fairly big job ? thank you could there be some possible carbon in that engine making it also ping ? that could be cleaned ?
Azrael91966669
25
Jun 20, 2017 04:04 AM
Dwayne614
Sep 28, 2015 08:33 AM
Bubbajones_ya
Aug 28, 2015 02:17 AM
CamaroGuy350
Aug 26, 2015 05:11 PM
