Weird Problem
Old Nov 17, 2005 | 06:01 PM
82Camaro355's Avatar
Car: 1982 Camaro Sport Coupe
Engine: Modded Carbed 355
Transmission: TH350
Weird Problem
Ive been having troubles with getting my car to start. But the thing is that it will start perfect sometimes and other times it will just keep trying and trying and trying and wont start. Usually to get it to start I have to pop the hood, and open up the carb by hand. But when I do this some kinda smoke or gas or vapor comes pouring out of the carb. I have to let it all get out then it will start. Does anyone know what the problem could be?
Old Nov 17, 2005 | 06:06 PM
Transmission: TH350
Also, I am losing a lot of oil. I will have to put about a quart in a week. I dont know where it could be going, and I have checked the pan or leaks and it has none. I have ckecked to make sure the filter is on tight and it is. So, Im out of ideas. Anyone know what this could be?
Old Nov 17, 2005 | 09:10 PM
Vader's Avatar
If you have to open the choke plate by hand, the pull-off is probably not adjusted correctly, or is not working.
Not enough information on the oil. The two main possibilities are burning and leakage. If you aren't leaving puddles that attract Chevron workers when you leave the parking spot, it might be burning. A compression or cylinder leakage test might help identify problems with oil control.
Old Nov 17, 2005 | 09:30 PM
Transmission: TH350
How would I adjust the pull-off?
Old Nov 17, 2005 | 09:33 PM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Transmission: TH-350C
Axle/Gears: 3.43
New ones are about $15 here, i would just grab a new one.
Old Nov 18, 2005 | 07:42 AM
Vader's Avatar
This is all presuming that it is equipped with a standard E4ME or 4MV carb. Determine if the choke pull off is even operating. If it is, adjust (bend) the linkage rod so the pull off opens the choke plate the specified amount at 10" Hg. vacuum. Generally, the choke opening should be in the range of 0.200" or more - I'd have to look at the sheets to get the absolute correct specification.
EDIT: It appears that your's should be adjusted to a 0.130" opening, by the book.
Old Nov 18, 2005 | 11:52 AM
Transmission: TH350
It doesnt have the stock carb. At the moment I am only running a 2BBL Chevy carb. So I dont know if you can help me with that or not.
Old Nov 18, 2005 | 04:38 PM
Vader's Avatar
Is it a 2GC or a 2MV?
Old Nov 18, 2005 | 04:48 PM
Transmission: TH350
Im not sure. Are there any markings on the carb itself that would let me know what model it is?
Old Nov 18, 2005 | 05:20 PM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Axle/Gears: 3.43
If your lucky their should be a small metal tag attatched to one of the screws.
Old Nov 18, 2005 | 05:23 PM
Transmission: TH350
Nope no tags, but there are some numbers on the top of it. I cant get them tonight because its too dark, but I will get them in the morning. Would those help or is it even worth getting them?
db057
Apr 28, 2019 07:45 AM
383cam
Sep 9, 2015 06:01 AM
andy74
Sep 3, 2015 08:41 AM
GeneralIesrussi
Sep 3, 2015 03:23 AM
greenyone
Sep 2, 2015 03:39 PM
