Gear Drive (vs) Double Roller
Old Nov 26, 2005 | 07:30 AM
FLTraumaRN's Avatar
Car: 1988 Z28
Engine: 357 ci 472 hp at RWs
I have a SBC Built very nice with 472RWHP and it right now has a Cloyes Gear Drive for timing a little noisey but ok I was thinking of doing the Cloyes Double timing chain with Billit gears what do you all feel is better?
Old Nov 26, 2005 | 11:30 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Go with the chain.
Old Nov 26, 2005 | 01:31 PM
mw66nova's Avatar
Car: camaro sportcoupe
Engine: 7.0L
Transmission: G-Force GF5R
Axle/Gears: Moser 9"
i have heard of people having problems with premature cam failure while running timing gear drives becuase of the harmonics from the crank being transfered up into the cam through the gears. because of this, i'll never run a gear drive.
Old Nov 26, 2005 | 01:32 PM
Dens71TA's Avatar
Car: '82 Recaro T/A, '71 Trans Am
Engine: 305CFI/455HO
Transmission: TH700R4/M22
Axle/Gears: 3.23/3.42
Go with the chain. Gear drives are so 1970s!
Old Nov 26, 2005 | 02:43 PM
MattODoom's Avatar
Car: '88 G T/A
Axle/Gears: 3.27 9 Bolt
Gear drives have a nice whine. I was going to put one in my L98 but after talking to a friend of mine who builds engines, he said anything thats driven regularly shouldnt have one - the harmonics created are horrible for the engine.
My $.02
Old Nov 26, 2005 | 05:37 PM
SSC's Avatar
SSC
Car: 1989 C4
Axle/Gears: 307
Ive never heard of bad harmonics from a gear drive ruining engine components. I have however seen proof that a gear drive can eat as much as 10hp.
Old Nov 26, 2005 | 09:18 PM
klumb15's Avatar
yea i heard that too, also its more friction and heats up your oil more. And shouldn't be used with a computer controlled vehicle equiped with a knock sensor because it plays mind games with it. There is no real benefit for using them, so i dunno why people get them. The sound really isn't that sweet either...if you want your car to whine, buy a supercharger...otherwise your just bluffin..
thats my 2 cents
Old Nov 26, 2005 | 10:08 PM
DartByU's Avatar
Car: 92 Camaro RS
Engine: 305 TBI
A mag. tested gear drives, chains and belt drives a while back, all on the same engine and I think there was less than 1 hp difference between them, they even tested advancing and retarding the timing with the adjustable belt drive and found almost no difference. I like the true double roller myself.
Old Nov 26, 2005 | 10:27 PM
JesasaurusRex's Avatar
x2, read that same mag think its car craft, anyhoo get what u feel like, Ive run 2 gear drives in my motors so far and havent had any problems. I like the idea of a chain not stretching or snapping on you but tahts just me.
Old Nov 27, 2005 | 01:11 AM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
I currently have a single idler gear drive. Motor runs fine, haven't done any gear drive vs. chain or whatnot (can't afford a belt). Can't say anything about the whine as I can't hear it versus the exhaust.
Old Nov 29, 2005 | 12:15 PM
Guest
Guest
Posts: n/a
Bah, knock sensor doesnt care. And I dont know how many miles you need to ruin a cam from harmonics, but apparently 14k miles is not enough.
Thats my experience so far.
472RWHP? Go for the belt drive.
Old Nov 29, 2005 | 01:42 PM
my3rdgen's Avatar
Car: 2013 Challenger RT
Engine: 5.7
Transmission: 6 spd
Axle/Gears: 3:92
My brother and I put one in a carbed L98 we installed in his 86 Regal, I thought it sounded nice. Never had a problem with it. Did it add power? Of course not, at least not in a stock L98. Did it sound mean along with the headers and dual exhaust? Of course it did!!
I am planning on putting one in my car too. I had one in it but removed it before I installed the engine since I thought I was going to be using the computer. But the computer is gone now.
Hmmmm... Blower vs. gear drive. If its a cruizer like mine I will go for the gear drive. I just want a nice cruizer that can get into the 13's, shouldn't need a huffer for that.
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
jklein337
Sep 19, 2018 06:23 PM
Infested
May 22, 2018 11:56 PM
BrianI
Aug 9, 2015 11:52 AM
