What would low oil pressure mean on a good running car?
Old Dec 6, 2001 | 11:37 PM
missythehood's Avatar
I have a problem my oil pressure is very low be fore I did the oil change it was fine
I don’t see any oil leaking but if I ad a quart the oil pressure go’s up for a bout 15 min then very low but the car’s running fine the whole time
Old Dec 6, 2001 | 11:41 PM
Engineboy's Avatar
Car: yep
Engine: uhuh
Transmission: sure does
What is the pressure?
Usually 10psi for every 1000 RPM is all they really need.
ASE Mechanic/Machinist/Smog Tech
1999 NBM Trans Am
1986 Chevy 3/4 ton pick up
1981 corvette
1995 Kawi ZX6R
and 2 POS commuters...
R.I.P. #3
"He can see air"
Old Dec 6, 2001 | 11:45 PM
So what would that mean I have like no oil press
Old Dec 6, 2001 | 11:47 PM
The gauge reads 0-10 psi
Old Dec 7, 2001 | 12:08 AM
PLANT PROTECTION's Avatar
Car: 1987 Monte Carlo SS
Transmission: 200-4R
Axle/Gears: 7.625 10 bolt/3.73s
Check your dipstick to make sure you have oil. If you are reading the gage at idle, it should be under 10psi on a warm engine. Like engineboy said 10psi for every 1000RPM is ideal.
1989 Formula 350
Old Dec 7, 2001 | 11:56 AM
fordcrusher's Avatar
How old is this oil? If it's older than you are, and running off of the stick like **** on a post, then you need to change your oil, and preferably to a heavier weight for a couple thousand miles.
Old Dec 7, 2001 | 11:57 AM
Don't cross out the idea that your pump or gauge could take a crap.
Old Dec 7, 2001 | 01:12 PM
i have i just checked the dip stick the oil is fine what's up
Old Dec 7, 2001 | 01:21 PM
Allan's Avatar
Car: 1988 IROC-Z
Engine: 5.7L TPI
Axle/Gears: BW 2.77
don't rely on the dash oil pressure gauge. if you can get one, get an aftermarket gauge and check it with that. that way you know what the oil pressure really is. chances are, you have a faulty oil pressure sending unit or flakey gauge.
other then that, if you find out for sure that your oil pressure is dropping like that, then i'd look into cam bearings going out.
Old Dec 7, 2001 | 02:39 PM
RICH92RS350's Avatar
Car: 92 Camaro RS
Engine: 350 Crate Motor
Transmission: Tremec TKO
Axle/Gears: 10 Bolt 3.73
If the valvtrain's not rattling when it shows very low,it's probably the oil pressure sender.Mine's been erratic for a long time.Finally replaced it when I replaced the motor.
A good mechanical gauge will give you peace of mind.I added mechanical gauges for oil pressure and water temp as soon as I started to have troubles with the factory sending units.
Otherwise, like engineboy said, 10 psi for every 1000 rpm minimum is the rule of thumb.
-Rich-
Old Dec 7, 2001 | 02:48 PM
L98IROCZ89's Avatar
Car: 1989 IROC-Z
Engine: 350 Vortech Supercharged ZZ4 TPI
Could be many different things wrong and I am not about to guess.
However, DO NOT INVEST TO MUCH TRUST IN THESE IN DASH GAUGES!!! They are not gospel.
1989 Chevrolet Camaro IROC-Z
L98 - 350c.i. TPI, rebuilt 700R4 auto w/shift kit, Dual catalyst Monza PaceSetter Cat-Back, SLP 1 5/8 Coated Headers, 3.23 Posi rear, Hypertech Thermomaster chip with 160stat, MSD 6A, March Under-Drive pulleys, AFPR, K&N's, !Air Box w/ Ram Air, moddified MAF, !TB Coolant, Spohn Dual Cat SubFrame Connectors, Alarm, Keyless entry, remote starter, 92 Z28 AeroWing, Brand New Paint (6/21/01)
Future: ZZ4 TPI w/EGR, T56, 3.42 or 3.73, Spohn strut tower brace and LCA's, Accell Universal 24# injectors
More info and pics on my webpage:http://go.to/iroc-z
AOL IMer: GPA 0point0
specialized
Jun 18, 2022 09:26 AM
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
86IROC112
Aug 17, 2015 02:00 PM
Kaweh
Aug 9, 2015 02:54 PM
gwade12
Aug 8, 2015 08:17 AM
