Condensation
Old Nov 30, 2005 | 02:22 PM
rjpbboi's Avatar
Car: 87 Trans Am, 89 RX7
Engine: 350tpi,350carb
Transmission: T-5,t56
Axle/Gears: 3.42 Posi,4.11 posi
Condensation
I popped my hood today and I noticed a lot of condensation in the engine. I have a pic that follows. I know this is bad for the engine I'm just wondering how bad (I figure electronics mostly but I didnt wanna post this there) and would a car cover (I would use a bed sheet because I really don't have any money) counter this?
Old Nov 30, 2005 | 08:22 PM
scribbles's Avatar
Car: 88 gta
Engine: 350 tpi
clean that motor..
Clean That Motor... also check your thermostat it looks like it is leaking. All water is bad for a car, but they get wet there whole lives. wouldent worry bout it. Only thing that would help is puting it in a garage.
Old Nov 30, 2005 | 08:53 PM
rjpbboi's Avatar
It is in a garage, thats y I didnt understadn y all the condensation, its only this car, my moms camry's fine.
Old Nov 30, 2005 | 09:31 PM
Vader's Avatar
Just how close to the ocean ARE you? A little engine bay cleaning and sealing may help, but a bit of heat in the garage may help keep the moisture out of there completely. The condenstaion isn't helping the structure or the concrete either. A cover won't help. You need ventilation and some way to drive the moisture out of the building.
Old Dec 1, 2005 | 06:17 AM
rjpbboi's Avatar
We have a storage bay in our garage where all the air from the dishwasher and stuff come from. It's a source of heat but its pretty far away, but it kinda heats the whole garage. Do u think if I opened a window (theres one next to the passenger door in my garage) it would help?
Old Dec 1, 2005 | 11:08 AM
Vader's Avatar
All that air is probably the source of all the humidity as well. You'd be better off storing the car outside in that case - After it has been cleaned and protected. I can't imagine what the body looks like.
Old Dec 1, 2005 | 11:12 AM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
Dehumidifiers work pretty well I hear.
Old Dec 1, 2005 | 03:47 PM
rjpbboi's Avatar
I degreased the engine, but I didnt wanna get too clost to the spark plugs so a lot of the waste around those are still pretty bad, i might just do that part again tommorrow and just use degreaser on a toothbrush and then use water and scrub on another toothbrush.
Old Dec 1, 2005 | 06:50 PM
scribbles's Avatar
Car: 88 gta
Engine: 350 tpi
clothes dryer
Do you have a washer and drier in the garage, if the clothes drier is venting its waist hot air into the garage it will spike the humidity to well over 100%, and any metal will cool the water vapor and it will condense like crazy. The Camry is mostly plastic and plastic doesn’t condense water vapor as well. Plastic has a lower ability to transfer heat and condense the water. It will condense water, just not as dramatically as bare aluminum.
or is the garage new? it takes a lot longer for concrete to cure fully than ppl expect. I have seen it take up to 5 months to dry out if a structure was built on it two quickly. The structure traps the moisture. Also try opening a window during the day, and closing it before you go to sleep, it may help reducing the moisture in the air. If all else fails, dehumidifier.
Old Dec 8, 2005 | 10:13 PM
scribbles's Avatar
Car: 88 gta
Engine: 350 tpi
diging agian...
you ever figer out what it was?
Bubbajones_ya
Jul 6, 2024 08:32 PM
b4ccamaro
Jun 5, 2016 01:48 PM
my86bird
Oct 23, 2015 12:20 PM
Street Lethal
Aug 13, 2015 08:28 PM
Street Lethal
Aug 12, 2015 11:33 AM
