Help Setting Valve Lash
Old Dec 6, 2001 | 03:43 PM
Remondi2's Avatar
I have your average 5.7L TPI mill. I have reason to believe a resent rebuild has left the valve lash adjusted improperly. Which method is best for my hydralic roller lifters; with the engine running or by rotating it into position by hand? Has anyone done this before?
thanks
[This message has been edited by Remondi2 (edited December 06, 2001).]
Old Dec 6, 2001 | 03:53 PM
irocbsa's Avatar
I did mine with the engine running. Back off the nut until you hear the valve tapping. Then tighten it back until it stops. Simple as that. Worked nice for me until one of the threads for my rocker sutde stripped out. Grrrrrrrrrrrrrrrrrrrr.........
If you don't fab up some sort of shield for the oil it will splash all over the headers though.
bsa
"If they do not run, Then they will die." - Stonewall Jackson
'87 IROC, 355 TPI, Converted to SD, 700R4, B&M Megashifter, 3.42, Trick Flow Twisted Wedge Heads, Edelbrock Intake, Accel Runners, Comp Cam, Crane Gold rockers, Lucas 24# injectors, Edelbrock headers, Flowmaster 3'' exhaust, Mallory Ignition, Shift Kit, Corvette Servo, 2,000 Stall Torque Converter
1991 RS, 305 TBI, T-5, Bone stock daily driver.
Old Dec 6, 2001 | 04:02 PM
Remondi2's Avatar
What part of the head does the oil shoot out of...
Old Dec 6, 2001 | 04:08 PM
spartyon's Avatar
Car: 1986 camaro
Engine: 383 sbc
Transmission: th-400
Axle/Gears: 4th Gen 10 bolt/Detroit TrueTrac 4.
what i did after my new cam a while back was to find when the number one cylinder was on compression and then went with what the haynes manual said to set the valve at. i just tapped the key to turn the engine. it is better than spewing oil all over.
86 berlinetta
350cui w/.30 over
.526 hilift cam
hooker supercomps
3" duals
edelbrock streetmaster
holley 750 dp
bad asshauler
Old Dec 7, 2001 | 09:50 AM
Remondi2's Avatar
Old Dec 7, 2001 | 10:23 AM
82camaro's Avatar
Car: 82 camaro SC
The oil comes up through the pushrods. The rockers sling it around pretty good.
350 with stealth intake, holley carb, 470 lift cam. 700r4 with .5 boost valve, vette servo, tci lock-up kit, B&M megashifter. Richmond 3.73 gears, powertrax locker, timkin bearings, synthetic lube. Custom 3 inch single into 2 2.5 pipes. 1 1/2 drop springs, 1 5/16 solid front sway bar, 1 inch rear bar, custom subframe connectors, custom LCA relocation brackets. Kobel ground FX, currant red metallic paint. Lots of other stuff...
82camaro
Old Dec 7, 2001 | 10:39 AM
tpi_roc's Avatar
I did it both ways. When it was all said and done the LITTLE bit of oil slung around was worth it to do it with the car running, its a WHOLE lot faster.
I took a piece of cardboard and cut it to shape and stuck it on either side of the head, backed the nut off untill I heard the ticking then tightened it up untill It stopped, and then went 1/2 turn after that.
1985 Iroc-z, 14 second 305, new engine in the works.
Old Dec 8, 2001 | 01:32 AM
rezinn's Avatar
Its pretty easy to do it without the engine running, just takes a bit of patience.
lakeffect2
Aug 23, 2015 08:44 AM
SLNTSCPE
Aug 22, 2015 09:15 PM
cstrobel65
Aug 15, 2015 10:19 AM
1988iroc350tpi
Aug 14, 2015 07:52 PM
