ok, now im sure my car is being possesed
Old Dec 8, 2001 | 03:47 PM
88camaro's Avatar
k, in addition to all the problems i've had, and fixed, this morning, driving to work at 6 am (ish) i hear a clunk and my gauges stop working (except for the odometerand speedometer), then stoped on a hill , for a few seconds my brakes wont work, and i rolled up to the red light and started rolling down, so i put it in first and hold it in place till the green light,
the rest of the way , it was fine 9exept for the gauges) after work i came to my car and figured to take a look at the fuse panel, and well, the fuse named gauges is blown so i reach to my wallet (remmembering i put a fuse there about a week ago) and replaced the broken fuse, turn the key and the fuse bows again, (gauses dont work, and there is no check engine light with the key in on, engine not running (i think it should be on).
anyone have any idea to what might have happened ???
Old Dec 8, 2001 | 04:20 PM
burntblues's Avatar
Car: 1989 Camaro RS
Engine: 355 mildly modified
Transmission: 700R4 fully modified
I don't think that the service engine lite is on the same circuit as the gauges, but theres a chance. You have a short somewhere, probably from excessive moisture causing corrosion. I'd pull the panel off and then take the instrument cluster out and clean up any rust you find.
What happened with the brakes? Did the pedal just go soft and then it pumped back up? If I were you, I'd probably get the brake thing straightened out first...
Mike
1989 RS.. 355, Hypereutectic pistons, double roller cam, double roller timing chain, accel wires, blue streak cap and rotor, rapidfire plugs, chevy caprice 350 chip, 200* fan switch, 3 angle valve job, 3 inch cat-back exhaust, 3 core radiator, 3.73 gearing with POSI.
Old Dec 8, 2001 | 04:47 PM
88camaro's Avatar
i actually dont know what happened with the brakes i was climbing the hill, when i saw a red light i just downshifted untill it almost stoped then used tried to use the brakes to brake and stay in one place till the light'll turn green, now, because of the hill the car coasted t oa stop (like 30 cm , and started sliding down, at which time i shifted to 1st and held it in place for about 5 seconds till the light turned green, my brakes were fine for the rest of the way there and back home , and another thing i noticed and forgot to post is that when i switch on the headlights theres a long beeeeeeeeeeeeeeeep untill i switch them off , the same sound it makes to remind u to turn off the lights when u switch of f the engine
Old Dec 8, 2001 | 05:19 PM
nagga's Avatar
do u have an aftermarket cd player or tape player? if so disconnect it and replace the fuse for the gauges, u can just take out the radio fuse if its wired right, even if its stock radio try pulling the radio fuse anyway just to check
Old Dec 8, 2001 | 07:07 PM
88camaro's Avatar
yes, its an aftermarket one but it's been installed for over 3 month allready couldent suddenly go bad . could it ?
and another symptom i noticed is that when i turn my headlights on,(while engine running , driving) the car makes a beeeeeeeeeeeeeeeeeeeeep untill i turn them off
Old Dec 8, 2001 | 08:51 PM
@ZZKKER's Avatar
Car: 86 iroc, 87 iroc, 89 iroc, 89 formula, 84 supra, 85 trans am
Engine: t\a motor 355 lt1 intake, t56,the works, 89 roc 427 sbc tt project
Transmission: to many to list
Axle/Gears: 9bolt 4:10 in the T/A
first off, when you put your new stereo in, did you use the clip on the stock wiring harness or did you wire it directly to the stereo. becase if you did you might have used the wroong ground wire because i had the same problem until i changed to the other ground wire. there are 2, one you use and the other blows the fuse for the gauges. if you are still using the factory clip, check and make sure the wires for the stereo are not touching the metal brakets around your stereo or you will have the problem you have.
Old Dec 8, 2001 | 08:59 PM
82camaro's Avatar
Car: 82 camaro SC
I have to agree with the radio thing. My cousin hooked up his wrong and when ever he flipped the lights on, the fuse blew. Take the radio out, put in a new fuse and see what happens.
350 with stealth intake, holley carb, 470 lift cam. 700r4 with .5 boost valve, vette servo, tci lock-up kit, B&M megashifter. Richmond 3.73 gears, powertrax locker, timkin bearings, synthetic lube. Custom 3 inch single into 2 2.5 pipes. 1 1/2 drop springs, 1 5/16 solid front sway bar, 1 inch rear bar, custom subframe connectors, custom LCA relocation brackets. Kobel ground FX, currant red metallic paint. Lots of other stuff...
82camaro
Old Dec 9, 2001 | 12:39 AM
88camaro's Avatar
oh, i know about the lights on fuse blow thing i've had it when i first nstalled the stereo, i fixed it and its been fine for two month, now the fuse doesnt blow when i turn on the lights it blows when i turn the ignition to on, when i turn on the headlights it merly makes a beeeeep sound
thnx for the help anyways, any more ideas?
Old Dec 9, 2001 | 04:21 PM
88camaro's Avatar
any ideas ?
Frozer!!!
Jan 19, 2024 04:55 PM
Reddeath210
Oct 6, 2015 08:20 AM
Linson
Aug 21, 2015 02:12 PM
kyleb24
Aug 15, 2015 08:24 AM
bryan623
Aug 10, 2015 11:33 AM
