Why is my car vibrating?
Old Dec 8, 2005 | 08:17 PM
Tripper511's Avatar
Car: 1982 Trans Am
Engine: 350 4BBL
Transmission: 4 Speed Manual
Whenever I'm in 4th gear going at above 3 grand on the tach (my speedometer doesn't work ) the car starts to shake. I know its not the transmission, so my only guess is the wheels or the drive shaft. Anyone ever have this problem or know how to fix it? Thanks!
Old Dec 8, 2005 | 08:30 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
Have your tires' balanced checked for starters. Could also be driveshaft.
Old Dec 8, 2005 | 08:31 PM
91ChevyRS's Avatar
Car: 1998 Volvo S70
Engine: B5254S Engine
Transmission: Automatic
Axle/Gears: It's a volvo?
could be something as simple as engine mounts, if it happens upon first gear acceleration and the car vibrates it is most definitely engine mounts.
Old Dec 8, 2005 | 08:33 PM
1989GTATransAm's Avatar
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
Is your cell phone on vibrate?
Old Dec 8, 2005 | 09:12 PM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Transmission: TH-350C
Axle/Gears: 3.43
Im guessing driveshaft
Old Dec 8, 2005 | 09:34 PM
7plagues's Avatar
Car: 92 Precision Red Firebird
Engine: v6->357 vortec xe262h rpm intake
Transmission: t5-> t56
Axle/Gears: 10bolt 3.42s
do you have a clutch fan?
Old Dec 8, 2005 | 09:39 PM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Axle/Gears: 3.43
Highly doubt thats it...
If its only at high speed not high rpm in all gears its something after the trans.
Old Dec 8, 2005 | 09:50 PM
7plagues's Avatar
nm i just read 4th gear, my bad. sounds like a driveshaft.
Old Dec 9, 2005 | 08:43 AM
Tripper511's Avatar
Car: 1982 Trans Am
Engine: 350 4BBL
How do I check to see if it's the driveshaft?
Old Dec 9, 2005 | 03:16 PM
Ricktpi's Avatar
Car: 1987 Camaro Z-28
Engine: 6.3L Victor EFI
Transmission: Tremec TKO 600
Axle/Gears: Moser 9"/4.11 Trac-Lok
First check your trans mount to see if the rubber part is cracked or broken. Next, accelerate to the speed it occurs & slip it into neutral & see goes away or stays. If it stays it's happening from the driveshaft back. On a 700R4 in 4th gear the driveshaft is turning 30% faster than the engine, so any driveshaft imbalance will be magnified. Have the wheels balanced & see if it goes away. Also have the wheels checked for runout while they are on the balancer (or ask for the tech to do it). This will eliminate the simplest thing. If it is still there look into an aluminum driveshaft from a 4th gen.
Old Dec 10, 2005 | 12:23 PM
Tripper511's Avatar
Car: 1982 Trans Am
Engine: 350 4BBL
ok, I know it's not the transmount, because I had the whole thing rebuilt a few weeks ago. <p>The vibrating still happens when I drop into neutral at high speeds but sometimes the car doesn't rumble at all (it's rare) at high speeds, which leads me to belive that it has to be a balance issue.<p>O and what do you mean check for runout?
Frozer!!!
Jan 19, 2024 04:55 PM
Reddeath210
Oct 6, 2015 08:20 AM
Linson
Aug 21, 2015 02:12 PM
kyleb24
Aug 15, 2015 08:24 AM
bryan623
Aug 10, 2015 11:33 AM
