Which 350 to rebuild?
Old Dec 11, 2001 | 10:30 AM
Hulk0202's Avatar
Im going to rebuild a 350 and I need to know which short block is best to start with. I want to use the crank, rods, and pistons. Heads, intake, cam, carb, Im going to buy. Is there any advantage to getting an lt1 if I'm only using the short block? Thanks for your help.
Old Dec 11, 2001 | 12:13 PM
Hulk0202's Avatar
btt
Old Dec 11, 2001 | 12:24 PM
FAST383's Avatar
If you get an LT-1 block you will have to get the LT-1, LT-4 heads, they're reverse flow and so is the LT-1 block. You will also need the LT-1/4 intake and opti system, unless you plan to convert to carb(pita).
hope any of this helps, I love my LT-1 but the parts are a little more expensive than reg 350's and not much is really interchageable between gen I and gen II small blocks.
L8TR
Josh
95 Formula
Stroked, and Sprayed
Way too fast
Now packin a beastly 86 LG4 Camaro w/Edelbrock Carb, Headman Headers/y-pipe. Shift kit, and flowmaster!
BumpaD82
Members Firebirds
31
Apr 4, 2019 10:36 AM
Magman
Sep 13, 2015 08:43 AM
fbirdroller
Sep 2, 2015 10:27 PM
transamgta87
Sep 1, 2015 07:07 PM
Eric-86sc
Aug 24, 2015 09:01 PM
