aluminum head torque sequence the same as iron?
Old Dec 12, 2005 | 11:56 PM
mw66nova's Avatar
Car: camaro sportcoupe
Engine: 7.0L
Transmission: G-Force GF5R
Axle/Gears: Moser 9"
wondered if there was anything different about torquing the heads to the motor when running aluminum heads. specifically torque specs, not really the sequence as i assume the pattern will be the same. running a stock 113 casting aluminum vette head.
Old Dec 13, 2005 | 12:02 AM
305sbc's Avatar
Car: 1986 Irocz
Axle/Gears: 3.25:1
Sequence = same.
I just take a couple more steps in the process... usually about 5.
Old Dec 13, 2005 | 12:17 AM
GOY's Avatar
GOY
Car: Formula, a big red brick.
Engine: A Ford 351 Windsor... ?
Transmission: Dodge 727
Originally posted by 305sbc
Sequence = same.
Are those steps hidden behind a very well guarded door, or could you share them with us?
Old Dec 13, 2005 | 01:36 AM
305sbc's Avatar
Car: 1986 Irocz
Axle/Gears: 3.25:1
I just mean I break the total torque down into 5 torqing steps.
for example, if the total will be 50 lb ft per bolt, then maybe go 10 lb ft on each bolt and then start the sequence over adding another 10 lb ft.. etc.
That's all I meant.
Old Dec 13, 2005 | 08:53 AM
mw66nova's Avatar
Engine: 7.0L
so is 50lbs. what i torque them to? more/less?
Old Dec 13, 2005 | 09:49 AM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
lol, no, he was giving a easy example of steps.
you need to follow the TQ specs that match your bolts.
if you're using GM bolts, you can follow the haynes manual specs.
if you're using ARP bolts, follow thoes specs that came with the bolts.
if you're using some other companys bolts, follow thoes specs that came with the bolts.
the torque specs ALWAYS ALWAYS ALWAYS go with the bolts or studs.
Old Dec 13, 2005 | 11:09 AM
mw66nova's Avatar
Engine: 7.0L
oh...cool that's all i needed to know then!
Old Dec 14, 2005 | 09:21 PM
Irockz's Avatar
Car: 87 Berlinetta,work in progress
Engine: 468 BB,still in the build process
Transmission: TH350,3500 stall
Axle/Gears: 9" Ford,learning how to live under
Same sequence,I usually go 70lb.ft. on aluminum,I go in 3 steps,30,50,70lbs.,and ALWAYS retorque aluminum heads.You'd be amazed how much you can tighten aluminum on a retorque.
midge54
Dec 27, 2019 04:14 PM
bdads
Aug 24, 2015 06:01 PM
InfinityShade
Aug 22, 2015 08:00 PM
Zeek1041
Theoretical and Street Racing
Aug 21, 2015 08:45 PM
