which crank to purchase?
Old Dec 23, 2005 | 02:21 AM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
Axle/Gears: Stock IRS
i cant seem to find this correct crank i need for my engine, its a stroker crank one piece rear main seal, with 6" rods.
i have this one bookmarked, http://store.summitracing.com/defaul...=egnsearch.asp
however it says for 5.7" rods. is this gonna be an issue?
Old Dec 23, 2005 | 02:41 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
If it will work with a 5.7" rod, it should work with a 6" rod. The reverse isn't always true though, using a shorter rod than specified could have counterweight to piston clearance problems.
Old Dec 23, 2005 | 02:47 AM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
good point , nothing the shop cant take care of right? (adding counterweights i mean )
Old Dec 23, 2005 | 03:22 AM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
That's why you have it balanced, yes.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
MM2Robinson
Oct 1, 2017 09:16 AM
camarohelp
Sep 22, 2015 03:19 PM
383cam
Sep 9, 2015 06:01 AM
Formula_88AE
Sep 3, 2015 01:47 PM
