Problems Getting On It
Old Dec 24, 2005 | 02:35 PM
RST89's Avatar
Car: 1983 camaro
Engine: 2.8...... 3.8t coming soon or should I do a ls6 almost the same cost hmmm.....
Transmission: 3spd soon to be either a 700 or t56....
Ok when ever i try to just floor my car from a stop or do a good accel it seems to big down and almost want to stall, also when i shut it off every now and then it trys to back fire or well it does but not all the time shy the hesitation ?? Also relate to my computer wont give codes thread dont know if that has anything to do with it or not ? Thanks for the help in advance
Old Dec 24, 2005 | 03:00 PM
ZZ28ZZ's Avatar
Car: 82 Z-28
Engine: 383 TPI
Cross Fires are very sensitive to low fuel press.
Check fuel press.
The fuel filter is supposed to be replaced every 30K miles, but most people don't.
Remove fuel filter and try to blow thru it (after you drain the gas out of it). You should be able to blow thru it with no restriction at all.
Old Dec 24, 2005 | 03:58 PM
RST89's Avatar
Car: 1983 camaro
are you talking about the on in the carb or in the fuel lines??
Old Dec 24, 2005 | 11:40 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
Technically, they're throttle boddies.
And they run off the same fuel pressure. Check them both at the inlet to each throttle body.
Also, check the timing.
Old Dec 24, 2005 | 11:45 PM
mw66nova's Avatar
Car: camaro sportcoupe
Engine: 7.0L
Transmission: G-Force GF5R
Axle/Gears: Moser 9"
wait, which car are you talking about? what is the setup? give us more info!
Old Dec 25, 2005 | 01:47 AM
RST89's Avatar
Car: 1983 camaro
it is a 83 2.8 with a 2bl carb. I dont think that i have a fuel filter anywhere other than directly in the carb.
Old Dec 29, 2005 | 08:03 PM
RST89's Avatar
Car: 1983 camaro
ttt ok not fuel pressure waitint on timing light but pretty positive that it is correct also. so any other options i will let you know about the timing.
Old Jan 1, 2006 | 10:07 AM
RST89's Avatar
Car: 1983 camaro
k still havent done anything with my timing but i did find a very large vacum leak so that fixed the probem of almost stalling from a dead stop to WOT but the car is still dieseling as far as still sucking to much gas i dont knwo yet i will let you know on that later. so is it my timing or is my car running to rich??
Old Jan 5, 2006 | 07:10 AM
RST89's Avatar
Car: 1983 camaro
ok i have all the vacume line correctly connected now it seemed to oh helped a little but still didnt fix the deiseling problem i am now smelling something like maybe gas in the car an unusual smell for my car does anyone now how to adjust the oem 2bl carb for a 83 2.8?? or any other suggestions?
pjsparts
Oct 29, 2025 06:39 PM
88rscamar0
Sep 23, 2015 09:08 PM
Ranbo108
Sep 9, 2015 12:20 PM
383cam
Sep 9, 2015 06:01 AM
andy74
Sep 3, 2015 08:41 AM
