Decent Combo / Will it work?
Old Dec 25, 2005 | 11:07 PM
koll's Avatar
Car: 1991 Pontiac T/A Vert
Ok, 2 part question. First off, will this setup work. IE No problems bolting right up.
Second part. Car is a 91 Trans Am Vert with 350 TPI From 89. Stock except for Exhaust and a custom chip.
Parts :
Cam : "XFI" 292 Hydraulic Roller Camshaft Lift: .584"/.579" w/1.6 Rockers Duration: 292°/300°
Intake : LT1 converted intake from LT1intake.com
Heads :SBC Pro Series Aluminum Cylinder Heads
The heads are the biggest problem. They are 23*. Stock is 18 if I remember. Am I going to run into a problem?
Old Dec 25, 2005 | 11:16 PM
RWB____s's Avatar
Car: Z/28
Engine: 355
Transmission: Turbo 400
Re: Decent Combo / Will it work?
Parts :
The heads are 23* heads which are stock not 18*.
heads are raised port heads and will not fit with the LT1 intake.
Old Dec 25, 2005 | 11:47 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
will the custom chip support that kind of duration? that's pretty wild...
Old Dec 26, 2005 | 12:08 AM
mw66nova's Avatar
Car: camaro sportcoupe
Engine: 7.0L
Transmission: G-Force GF5R
Axle/Gears: Moser 9"
this is where you get to start learning about Prom tuning my friend, i hardly doubt that the chip will work well at all. check out the TPI and PROM boards.
Old Dec 26, 2005 | 07:13 AM
koll's Avatar
Its a custom chip from a live tune
Old Dec 26, 2005 | 10:33 AM
mw66nova's Avatar
Engine: 7.0L
yeah, but your changing the combo, right? that custom chip is tailored to your current combo. it would be like expecting the jetting in my holley for my 305 to work on my 350 w/ 10.2:1 c/r and a 230/236 cam @ .050...
Old Dec 26, 2005 | 05:18 PM
koll's Avatar
The kid is local who does it so I just gotta get a hold of him.
Old Dec 26, 2005 | 07:05 PM
mw66nova's Avatar
Engine: 7.0L
good, have him do a real time tune on it after you get the new motor together.
mitch_04
Members Camaros
20
Sep 20, 2021 02:24 PM
midge54
Dec 27, 2019 04:14 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
IMissMy86TA
Aug 31, 2015 08:40 PM
NufNuffZ28
Aug 14, 2015 09:12 AM
