oil lose
Old Jan 4, 2006 | 07:09 PM
F5Storm91's Avatar
Car: 88 Camaro
Engine: V6 MPFI
Transmission: A/T
oil lose
OK so i know where the leak is coming from but im out of ideas on how to fix it. Its coming from the vavle cover breather. it seems loose but i dunno how... it smokes form that side and it has oil spray over all over the place. how do i fix this?
Old Jan 4, 2006 | 07:36 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Check your PCV.
Old Jan 4, 2006 | 07:38 PM
WhiteHawk's Avatar
Car: 1991 Firebird
Engine: 350,Dart Heads,Weiand In,Roller Cam
Transmission: 2400-Stall, 700R4 w/ Kit
Axle/Gears: 4th Gen 3.42 disc (I wish)
Take the valve cover off, make sure the oil return passages on the head arent clogged with carbon. Inspect the rods/rockers for abnormalities and put a new valve cover gasket on. Smoke is just from oil burning off your manifolds.
Old Jan 4, 2006 | 07:40 PM
F5Storm91's Avatar
Car: 88 Camaro
Engine: V6 MPFI
Transmission: A/T
its on the other valve cover not pcv... i already fixed that side. could it be because of the grommet as gone bad? i remeber way back when it was harder to get the breather in and out of the hole
Old Jan 4, 2006 | 07:43 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
If it's blowing smoke from the breather, you probably have excessive crankcase pressure. This could be from a plugged PCV system, or excessive blowby or something.
Old Jan 4, 2006 | 07:44 PM
F5Storm91's Avatar
Car: 88 Camaro
Engine: V6 MPFI
Transmission: A/T
the breather is loose.. when the car is off. the pcv is new. ima replace the ruibber grommet and see if that helps
Old Jan 4, 2006 | 07:50 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
The PCV valve is new, but does it have any vacuum on it?
Old Jan 4, 2006 | 07:56 PM
F5Storm91's Avatar
Car: 88 Camaro
Engine: V6 MPFI
Transmission: A/T
i think so... it should
WhiteHawk's Avatar
Car: 1991 Firebird
If there is that much pressure, the PVC should still release the pressure. If you got that much crank case pressure to build up pressure and blow out your seals, you need to look into the real problem.
Old Jan 4, 2006 | 07:58 PM
F5Storm91's Avatar
Car: 88 Camaro
Engine: V6 MPFI
Transmission: A/T
i dont beleive its that. liek i said earlier the breather was really tight int he grommet nows its loose.. so im guessing that my problem.. but ill looks into these other tings
PurelyPMD
May 5, 2016 04:57 PM
tyeo098
Nov 30, 2015 06:27 PM
skinny z
Oct 5, 2015 06:23 PM
Stryker412
Sep 20, 2015 06:59 PM
CatmanFS
Sep 19, 2015 09:00 AM
