Dying starter relay?
Old Jan 7, 2006 | 01:44 PM
Batass's Avatar
Car: 91 rs
Engine: Blow through 383, 10 psi, xr288hr
Transmission: Manual th350 ATI 3000
Axle/Gears: 3.50 9"
Every now and then when I drive my car short distances, it wont start back up. The battery is fine, but when I go to start I dont hear a click. Now if I get out of the car and manually turn the motor over a little using my hands on the ac pulley, itll fire right up. I used to hear a clicking/vibrating noise coming from the fuse box if I turned the key slowly between power and start. Could this mean my relay is about shot? Why would turning the motor help?
Old Jan 7, 2006 | 06:18 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
Almost sounds like the case of weak, crappy, direct drive starters is beginning to catching up to you. Try looking into (searching) that phenomenon they like to call "heat soak." See if any of the other posts look anything like your situation.
gta892000
Aug 11, 2019 11:16 AM
sahlomonic
Sep 20, 2015 07:15 PM
Denricci22
Sep 18, 2015 09:02 AM
gta892000
Sep 16, 2015 12:37 AM
Formula_88AE
Sep 3, 2015 01:47 PM
