head help
Old Jan 13, 2006 | 04:39 PM
muteboy49's Avatar
Car: 84 Camaro
Transmission: dont have one yet
Axle/Gears: 3.42 spool on the way
head help
ok as some of you know i have a set of 14102193 heads. at this point i dont have time to port them. should i just bolt them on and run them til next winter? or would i be better off with my 882's til next winter?
thanks guys
Old Jan 13, 2006 | 04:50 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
use more descriptive thread titles, geez.
i'd use the 193s.
Old Jan 13, 2006 | 04:51 PM
muteboy49's Avatar
Car: 84 Camaro
sorry
and thanks
Old Jan 13, 2006 | 05:04 PM
jims87camaro's Avatar
well, if you bolt up the 882s, you won't have to unbolt anything to drop the heads off (or get to work, if you're doing them yourself) and there will be zero downtime when they're ready to bolt back on, too.
i say bolt 'em up (882), worry about the 193s when the time comes.
Old Jan 13, 2006 | 06:55 PM
muteboy49's Avatar
Car: 84 Camaro
yeah but i gotta assemble my 882s lol
Old Jan 13, 2006 | 11:01 PM
Farmer Mike's Avatar
Car: 87 Chevy 4X4 TBI
Engine: L05
The 882s are 76cc heads unless they've been milled. The 193 swirlport heads are 64cc. If your motor had the 193s on it originally, 882 heads will seriously decrease the compression ratio. Not too cool...
Old Jan 13, 2006 | 11:03 PM
muteboy49's Avatar
Car: 84 Camaro
yeah. this is true but on the CR calculator id still have like a 10:1 CR with the 882s. but this is gonna be raced so im def. keepin the 193s
Old Jan 14, 2006 | 12:32 AM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
Unless you have some built engine, in which case, neither head would have a place atop it, you are doing something wrong with the calculator. 10:1 with 882s is close to 11 or so to 1 with the 193s.
Old Jan 14, 2006 | 12:34 AM
muteboy49's Avatar
Car: 84 Camaro
thats what it told me. i dont know my uncle did it for me. i forgot what size domes my pistons are so i cant do it right now either
Old Jan 14, 2006 | 11:58 PM
muteboy49's Avatar
Car: 84 Camaro
ok im port matching the intake and exhaust ports because it will help the heads a bit. how much does this really help?
Old Jan 15, 2006 | 12:01 PM
Sonix's Avatar
Car: 1982 Trans-Am
not much.
Hotrodboba400
Dec 10, 2019 07:07 PM
92projectcamaro
Jan 18, 2016 08:00 AM
FormulasOnly
Sep 6, 2015 10:42 AM
z28guy134
Sep 1, 2015 11:50 PM
