Pipe plug front oil gallery passages
Old Jan 21, 2006 | 11:41 AM
jonarotz's Avatar
Car: 91 Z28
I am going to tap the 3 holes in the front of my block and put pipe plus in them instead of the normal cheap plugs.
Does anyone know the thread size for the tap?
Old Jan 21, 2006 | 01:56 PM
ede's Avatar
ede
27 TPI, is that what you're looking for the pitch?
Old Jan 21, 2006 | 02:24 PM
jonarotz's Avatar
Car: 91 Z28
Actually aren't they classified by like 1/4NPT, 3/8NPT ect.?
That is what I was looking for.
Old Jan 21, 2006 | 04:31 PM
Vader's Avatar
That's what ede is telling you. A ¼" pipe tap is actually ¼-27 tapered. The holes for the Welch plugs at the front can be tapped ¼-27, the same as the holes at the rear:
Attached Thumbnails Pipe plug front oil gallery passages-reargalleryplugtap.jpg
Old Jan 21, 2006 | 06:34 PM
Tibo's Avatar
Car: 1991 Z28 Vert
Engine: 383 single plane efi
Axle/Gears: 8.8 with 3.73s
Make sure that when you buy the tap, you get the correct size. You are going to want the one that says 1/4 NPT.
Old Jan 21, 2006 | 06:42 PM
jonarotz's Avatar
Car: 91 Z28
Thanks alot guys.
Where is a good place to find these taps?
Old Jan 21, 2006 | 07:05 PM
jonarotz's Avatar
Car: 91 Z28
I was doing a little searching and 1/4-27 doesn't seem all that easy to find.
I have found 1/4-14 and 1/4-18 but that is about it.
Anyone want to sell/rent me one?
Old Jan 21, 2006 | 08:08 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Pipe taps are not listed by thread pitch. They're simply listed as 1/4, 3/8, 1/2 NPT. Pipe threads are tapered so a standard thread pitch tap will not work.
Any tool supply place will carry them.
Old Jan 21, 2006 | 08:14 PM
jonarotz's Avatar
Car: 91 Z28
Thanks Stephen 87 IROC
I was confused by the 27, I understood pipe threads to be just that 1/4"NPT, 1/2"NPT etc
Old Jan 21, 2006 | 09:46 PM
rgarcia63's Avatar
Car: 88' IROCZ
Engine: 388 TPI Motown 350 Race block
Axle/Gears: 2.77
27 threads per inch is for 1/16", and 1/8" NPT, 18 threads per inch is for 1/4", and 3/8" NPT.
Drill tap size for 1/4"-18 NPT is 7/16ths.
Old Jan 22, 2006 | 09:02 AM
Tibo's Avatar
Car: 1991 Z28 Vert
Menards and True Value Hardware carry them.
Old Jan 22, 2006 | 09:32 AM
grumpyvette's Avatar
btw a comon mod once youve installed those oil passage plugs is to drill a .032 -.036 hole in the center of the plug on the pass side of the engines oil passage plug on the front end to spray pressurized oil on the back of the cam/gear/timing chain .
a further mod is to cut a small grouve in the block where the LOWER distributor oil band forms part of the oil passage above the distributor/cam gear contact point to spray oil directly into that area.
and a small grouve in the lower lifter bore surface like this
http://www.compcams.com/catalog/335.html
these three mods tend to supply oil where its needed but the standard system tends to deliver less oil at low rpms, this tends to reduce wear while not effecting the oil pressure noticably (IF THE WORKS DONE CORRECTLY, and YOU ENGINE CLEARANCES were correct to begine with) especially if a high voluum pump and windage screen is used on a baffled 7-8 qt oil pan that you should be useing on a performance engine
Old Jan 22, 2006 | 10:32 AM
SLEEPER 86's Avatar
Car: 86 coupe
Engine: 383
Axle/Gears: 9 bolt 3.27 posi
great tips grumpy!
any chance of doing the first or second steps after the shortblock is assembled?(cam not installed yet)
Eric B
Old Jan 22, 2006 | 10:39 AM
if your CAREFULL those steps can be done with the crank assembly in place
Old Jan 22, 2006 | 11:57 AM
SLEEPER 86's Avatar
Car: 86 coupe
Engine: 383
awesome grumpy!
i think i'll have somebody with steadier hands than mine try it!(if i decide to go there.grease up the drill bit so the metal frags stick right?
E.B.
Old Jan 22, 2006 | 12:29 PM
"grease up the drill bit so the metal frags stick right?"
why??
remove the oil passage plug and drill it in a vise,useing a drill press,while protecting the threads with wood in the vise jaws
heres a drill chart, I use a 1/32" bit, as the smallest up to a #65
http://bobmay.astronomy.net/misc/drillchart.htm
on the grouve in the lower distrib band in the block, a few magnets and a triangle jewlers file makes short work of that problem as it only needs to be a few thousands wide and deep
Old Jan 22, 2006 | 12:36 PM
SLEEPER 86's Avatar
Car: 86 coupe
Engine: 383
gotcha!
looked right past the obvious!
Old Jan 22, 2006 | 06:26 PM
jonarotz's Avatar
Car: 91 Z28
Nice tips grumpyvette, I was going to drill the oil gallery plug, but the other tips sound good too.
I don't think I am to concerned about the lifter bore groove as I am running roller lifters.
Do you know of any pics floating around that show the dist. bore mod? Does this mod primarily just spray oil on the dist. gear?
Old Jan 22, 2006 | 06:48 PM
"Does this mod primarily just spray oil on the dist. gear?"
it sprays additional oil into the distributor/cam gear contact area
Old Jan 22, 2006 | 07:08 PM
Dialed_In's Avatar
Car: '88 IROC-Z medium orange metallic
NEVER do any kind of grinding or cutting on an engine once it's been final washed and assembly has started!!!
Old Jan 23, 2006 | 12:32 AM
IF your against some careful file work with a magnet to catch the
metalic dust, you can easily put the grouve in the lower distributor housings lower band
BTW the picture depicts the grouve SLIGHTLY SMALLER than IDEAL and accomplish almost the same result, the differance is that as you change the ignition timing your also changing the area the grouve sprays as it MOVES as the timing changes (unlike the small grouve in the block)
were not talking about major machine work here, 3 minutes with a jewlers triangle file can easily give you the grouve a few thousands deep and about 3/8" long thats necessary to spray extra oil on the gear contact area, and while its always a better idea to do all machine work then clean the block totally, youll get far more more metalic dust in your engine as the rings and cam lap in, durring a normale engine break in procedure than youll ever get by placing a good magnet (temporarily)next to the area while you file a 3/8" long grouve a few thousands deep. (as almost all dust is instantly trapped on the magnet)(in fact I seriously doubt any can escape the magnetic field)
"Any source for the magnets Grumpy? "
http://www.wondermagnets.com/cgi-bin...catalogno=0001
these are NOT REFRIGERATOR MAGNETS "#0001" can pick up a SBC cylinderhead, and you wont beleive the amount of crud they remove from your oil and prevent from reaching the bearings
© 2003 ForceField
Email us
toll free (877)944-6247 or (970)484-7257
Also, you can visit us at our retail store in Fort Collins, Colorado, USA at 614 South Mason Street!
Old Jan 24, 2006 | 02:41 PM
Vader's Avatar
And FWIW, if you're reading this and want to have oil holes in the front lifter gallery plugs, and don't want to tap the holes, and/or don't feel cozy running a tiny drill bit into your engine, you can pull the original cup plugs and install factory pieces that were intended for LT1 engines. Those came from the factory with a 0.030" hole in BOTH front plugs to help oil the timing chain and water pump drive gears. They are pennies each.
You can purchase 1/4-27 (¼" pipe) threaded plugs with the oil holes alread drilled for about four bucks each, GM P/N 361997, so all you have to do is pull the old plugs and thread the gallery holes:
http://www.sdpc2000.com/catalog/1831...h-035-Hole.htm
Old Jan 31, 2006 | 04:57 PM
jonarotz's Avatar
Car: 91 Z28
Hey guys I was able to borrow the tap from a co-worker, and it turned out great! You don't even need to drill first. Truly a piece of cake.
Thanks again for all your help and advice.
Old Jan 31, 2006 | 09:19 PM
Vader's Avatar
Glad it went well. I apologize for my error in quoting the "¼-27" thread. rgarcia63 gave you the straight scoop on thread pitches for pipe taps.
Are you going with the oiling plugs or just standards?
Old Jan 31, 2006 | 09:36 PM
jonarotz's Avatar
Car: 91 Z28
I am just going to drill the two side plugs at .030"
I also made a slight groove in the dist. hole.
1992 Trans Am
May 10, 2023 07:19 PM
toronto formula
Nov 10, 2015 06:17 AM
db057
Aug 22, 2015 08:17 PM
Navy8125
Aug 21, 2015 09:32 AM
bamaboy0323
Aug 15, 2015 07:20 AM
