When do Rods and Crank Break
Old Feb 11, 2006 | 02:02 PM
myfast3rdgen's Avatar
Car: Trans Am
Engine: 305 to 350 to 383 to BOOM!!!
Transmission: 5-speed
Axle/Gears: 3.73 10-bolt
What is the rating for stock 350 (2bolt) Crank and the Rods
Old Feb 11, 2006 | 03:17 PM
GuitarJunki17's Avatar
Car: 1990 IROCZ Camaro
Engine: 350 4bbl, 200cc Heads, 270hr Cam
Transmission: 700R4 w/ Trans-Go shift kit.
Axle/Gears: GM 10 bolt Posi
From what I have read, I would say at or not far past 400hp/500tq, but someone else who knows more than I do can chime in with a more accurate number.
Old Feb 11, 2006 | 05:01 PM
ede's Avatar
ede
if everything is straight and round with good oiling 400 wouldn't be a problem, 500 might be. it isn't like a hard number, but i'd start to really think about forged parts past 430 or so.
Old Feb 11, 2006 | 05:44 PM
Dialed_In's Avatar
Car: '88 IROC-Z medium orange metallic
All depends on how it's put together. 400 is pretty much the limit on a stock rod, 500 on a crank. Of course, internal balancing will help a ton. Eagle rods are a good alternative to stockers and punch the max up over 500 with no worries.
Old Feb 11, 2006 | 10:53 PM
88IROC350TPI's Avatar
Car: '89 IROC-Z
Engine: Canfield 195 headed 358ci
Transmission: TH350, Art Carr 9.5"
Axle/Gears: 3.92 Dana 44
you'll never know how much they can take until you break them... I've known plenty of folks making tons (500hp+) on stock rods and cranks for many many years. I also know plenty of folks who have attempted the same thing and broke soon after...
Old Feb 11, 2006 | 10:54 PM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
I broke a stock forged GM 1 piece crank with 279 RWHP cruising down the highway.
Old Feb 12, 2006 | 07:25 PM
LilJayV10's Avatar
Car: 89' T/A, 00' Firehawk
Engine: 406 Roller
Transmission: TH700R4 w/2800 stall
Axle/Gears: 3.23 Posi
I think something like that would be more a forging problem from the factory than a horsepower problem. however if it broke, it's still broke!!
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
MM2Robinson
Oct 1, 2017 09:16 AM
383cam
Sep 9, 2015 06:01 AM
john204481
Sep 7, 2015 03:22 PM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:35 PM
