LG4 dyno numbers for senior project
Old Feb 11, 2006 | 04:58 PM
calebzman's Avatar
Car: '85 TA
Engine: 350 turbo
Axle/Gears: 3.70 posi 9bolt
I need some info. My '86 TA has an Lg4 from '83 in it. So according to the tech. data, it would've had 150hp and 240tq. The only mods I did to it was gutting the cat. and making a dual snorkel intake. Are those numbers close to what I had?
The reason I need to know is that I'm using my turbo buildup for my senior project. But, I didn't do a pre-turbo dyno run just b/c I didn't want to have the cost of doing it twice. However, I do need some numbers to compare then to now.
So if anyone has actual dyno graphs of a stock lg4 or a website that does (maybe GM?), I'd appreciate it.
Old Feb 11, 2006 | 06:23 PM
Nate86's Avatar
Car: 1999 Saturn SL2
Engine: 4 cylinder
Transmission: 4-speed automatic
This is not exactly what you are looking for, but Hot Rod dyno'd their completely stock 82 LG4 and ended up with 145 HP @ 4000 RPMs and 165 ft/lbs @ 2400 RPMs. This is at the flywheel, not rear wheel horsepower. The LG4 is a pathetic engine in stock form.
Old Feb 11, 2006 | 06:58 PM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
BTW, I feel that the 165 FT/LBS was a typo. They made more like 265 ft/lbs when totally stock.
Not completely relivant, but my LE9 was very similar off the line and it made 160 RWHP @ 4,200 and 258 ft/lbs @ 2,800 with nothing more than some carb tweaks, a high flow cat, and a recurved distributer.
Old Feb 12, 2006 | 06:07 PM
89IrocZ350TPI's Avatar
Car: ws6
Engine: ls1
Transmission: m6
Isnt it 165 at the fly wheel? So thats only like 120-130 at the wheels
Old Feb 12, 2006 | 07:42 PM
Damon's Avatar
The factory did a pretty fair job of rating the original engines accurately. Age, time, modifications, and a lot of other factors can alter those figures (remember- they are carbureted engines with a zillion miles of vacuum hoses and tons of failure-prone emissions devices). 240 ft./lbs seems reasonable, but definitely on the high side for a stock motor. 150 HP is definitely reasonable- they were SLUGS.
It's was relatively easy to get some noticable increases in torque from these motors (bump up the ignition timing, richer secondary rods in the carb like those used in the L-69 305 HO motor) but meaningful peak HP increases were not as easily achieved. The pathetic cam, compression and exhaust system really put a cork in maximum HP production of these motors in stock form.
Reasonably fun up to 3000-3500 in sharp tune. Then the party went south pretty quick without uncorking some of the bottlenecks.
Old Feb 12, 2006 | 07:46 PM
Car: ws6
Engine: ls1
Transmission: m6
Yup...My old lg4 had full bolt ons and could only run low 15's.
Old Feb 27, 2006 | 09:55 AM
calebzman's Avatar
Car: '85 TA
Engine: 350 turbo
Are the power ratings from the tech. data at the rear wheels or crank?
Old Feb 27, 2006 | 10:42 AM
Mcdamit's Avatar
Car: 89' Iroc-Z G92
Engine: TPI 305 G92
Axle/Gears: Limited 9 bolt, 3.45
crank for the mag rating.
Old Feb 28, 2006 | 06:32 PM
calebzman's Avatar
Car: '85 TA
Engine: 350 turbo
Also, is torque affected by the drivetrain loss?
Old Feb 28, 2006 | 06:35 PM
Car: ws6
Engine: ls1
Transmission: m6
Yup...20% for an auto, 15 for a manual.
Old Mar 1, 2006 | 08:19 AM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
Losses are not fixed, the higher the RPM the greater the loss. The 700r4+10bolt+thirgen driveline loses about 18% at peak HP and around 12% at peak torque.
160/.82= about 195 FWHP
258/.88= about 293 ft/lbs
298/.82= about 363 FWHP
305/.88= about 346 ft/lbs
Old Mar 1, 2006 | 10:00 AM
calebzman's Avatar
Car: '85 TA
Engine: 350 turbo
With the turbo, peak hp and torque both occur around 5,000rpm, so would that make the losses 18% for both?
305/.82= about 372 ft/lbs
Also, if the tech. data is giving the hp and torque at the crank, shouldn't the rear wheel data be lower?
160*.82= about 132 FWHP
258*.88= about 227 ft/lbs
Dyno graph:
Old Mar 1, 2006 | 01:59 PM
Car: ws6
Engine: ls1
Transmission: m6
At my local dyno they say its the same amount lost for both horsepower and torque.
Old Mar 1, 2006 | 02:11 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Torque is measured, HP is calculated. HP=(torque x RPM)/5252.
In order for there to be a drop in HP, there has to be a drop in torque.
Make sense?
Old Mar 1, 2006 | 02:32 PM
2 different RPMs....
They lose the same percentage AT THE SAME RPM however.
That's at the SAME RPM.
Ever wonder why it bothers those of us with some professional experience when people start throwing around HP numbers?
Also note, this DOES NOT mean the same thing as "the difference between Desktop Dyno and DynoJet". Desktop Dyno, or for that matter even actual dyno readings from an engine stand, are VERY VERY DIFFERENT from factory ratings. I would expect a RW reading NO LESS THAN 25% LOWER THAN a Desktop Dyno prediction, and probably closer to 30%, because there's more things in between those 2 numbers than just "drive train loss". I.e. if Desktop Dyno says your motor will do 300 HP, then expect 280 out of it on the engine stand and 220 or so at the wheels; and it probably would be "rated" at around 260 by factory methods.
ericjon262
Sep 11, 2015 06:07 PM
Nick McCardle
Sep 10, 2015 08:36 PM
NastyEngines
Group Purchases
Sep 8, 2015 10:14 AM
