Surface finish for dry-flow manifold?
Old Feb 18, 2006 | 04:44 PM
Mark 89Formula's Avatar
What surface finish should I apply after porting a stock TPI intake base with a carbide cutter? I've got the SA porting kit with 40 and 80 grit sanding rolls and 2 types of cross buffs. I used the cross buffs on the last base I did but now I'm second guessing that decision. Appreciate any input. Thanks.
Old Feb 19, 2006 | 11:17 AM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
smooth as possible is fine for a dry flow manifold, you aren't looking for good mixing.
cross buffs should be a good finishing point.
Old Feb 19, 2006 | 12:28 PM
doc's Avatar
doc
Car: '87 IROCZ
Engine: 395 ZZ4
Transmission: ProBuilt 700R4
Axle/Gears: 9 bolt 3.70s
For air flow only, you want a mirror type finish, as smooth as you can get it, then polish it.
Old Feb 19, 2006 | 01:11 PM
Coach Hawk's Avatar
Car: 91' Pontiac Firebird
on the street, you'll never notice the difference between a 120 grit finish and a mirror finish. Maybe a HP or two, it's up to you if you think it's worth your time.
Old Feb 19, 2006 | 01:59 PM
Guys, thanks for the inputs. Based on what you say I'll go ahead and use the cross buffs to get the nice polish.
Old Feb 19, 2006 | 05:03 PM
Dialed_In's Avatar
Car: '88 IROC-Z medium orange metallic
Only time you want a rough finish is when you have fuel particles that you want to keep suspended. If it's dry flow you're lookng for, then polish the hell out of it.
Old Feb 19, 2006 | 09:48 PM
rx7speed's Avatar
Car: 2005 BMW 545i
Engine: 4.4L N62B44
Transmission: 6spd auto
Axle/Gears: Rotating
even with that I'm not so sure a perfect smooth finish. I've seen dry flow setups that had dimples or a little roughness in them to prevent the air from "sticking" to the surface kinda just like the fuel does
Old Feb 19, 2006 | 11:43 PM
Guest
Guest
Posts: n/a
Yea, cross buff is a good idea. TPI's arent exactly totally dry flow, there is some reversion and whatnot throwing some fuel mist around, not to mention EGR and PCV gasses. If you've ever taken off a runner and seen all the black stuff inside... well, thats not air!
Old Feb 20, 2006 | 09:38 AM
cuisinartvette's Avatar
Car: 67 ******mobile
Engine: 385 Solid roller
Axle/Gears: 4.11
You can use a 40 or 80 grit flapwheel, see my thread.
Crossbuff isnt necessary.
Old Feb 20, 2006 | 01:11 PM
You hit on my two concerns; 1) airflow over a sanded versus polished finish and 2) air-fuel mixture standoff and reversion.
Two examples for concern 1 come to mind. The dimples on the golf ball and the skin friction of a single drop of water as it moves over highly polished glass versus a slightly rougher surface.
And there definitely is more than just air going through the base. The good new is all that junk looks like someone used a black magic marker to show "port here". Even though the injector is pointed toward the cylinder head intake port, I believe that some of the air-fuel mixtures flows back into the base due to standoff and reflected pulses from the back of the closed intake valve.
Conversely I keep thinking about the smooth finish that Extrude Hone puts on intakes which supports the "polish it" theory.
It's good to be able to talk yourself in a circle.
Old Feb 20, 2006 | 01:29 PM
Guest
Guest
Posts: n/a
You could always polish all the right side, cross buff the left, and see if the engine has an imbalance after that.
Old Feb 20, 2006 | 01:49 PM
1991 RS 305's Avatar
Old Feb 20, 2006 | 08:12 PM
I like it.
sailtexas186548
Feb 17, 2017 03:07 PM
86CamaroDan
Sep 29, 2015 10:08 PM
sreZ28
Carburetors
24
Sep 21, 2015 04:54 PM
Linson
Sep 21, 2015 01:08 PM
Rally Smith
Sep 14, 2015 06:59 PM
