How do I reconnect the speedometer?
Old Feb 20, 2006 | 10:20 AM
Tripper511's Avatar
Car: 1982 Trans Am
Engine: 350 4BBL
Transmission: 4 Speed Manual
Ever since I bought my car the speedometer has been disconnected. I have no idea where to look to see where the cable for the speedometer hooks up. Do I have to take off the transmission or can I just go under my car and hook it up. Please help, this is the one thing preventing GM from giving me a new engine from my warrenty.
Old Feb 20, 2006 | 10:25 AM
82 Iron Duke's Avatar
Car: 04 Silverado
Engine: 4.8
Transmission: auto
Remove the speedo and look in the back to the left of the dash for the cable first, it just plugs in.
Old Feb 20, 2006 | 10:43 AM
Tripper511's Avatar
Car: 1982 Trans Am
Engine: 350 4BBL
If it is connected at the back where would be the next place to look?
Old Feb 20, 2006 | 10:52 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Transmission. Now that I think about it, some cars--and I don't recall the years--had a two-piece cable. Does your cruise control work?
JamesC
Old Feb 20, 2006 | 10:58 AM
rgarcia63's Avatar
Car: 88' IROCZ
Engine: 388 TPI Motown 350 Race block
Axle/Gears: 2.77
At the transmission driver's side of tail. It's a flexible metal cable.
Old Feb 20, 2006 | 11:19 AM
Tripper511's Avatar
Car: 1982 Trans Am
Engine: 350 4BBL
<P>I don't have cruise control. Im not sure if it makes a difference but I have a 4-speed manual tranny.<P>
<P>Can I get access to that by just going under the car or did I need to disconnect the tranny from the engine?
Old Feb 20, 2006 | 11:26 AM
JamesC's Avatar
Just crawl under. If the speedo cable is unattached, you'll see it hanging. Clean the end up a bit and put it in place. You'll see what needs to be done.
JamesC
Old Feb 20, 2006 | 12:13 PM
1985WS6transam's Avatar
Car: 1988 Firebird Formula
Engine: 388 Carb
Axle/Gears: 4.10
I just have a question, why is GM going to give you a new engine from a warrenty? Was your transmission ever swapped maybe from an auto to a manual or were your gears changed? usualy people dont just disconnect speedos, i know mine is not hooked up b.c when the engine tranny rear swap was done nothign was the same, plus it was an older tranny with a newer speedo setup... good luck.
Old Feb 20, 2006 | 12:34 PM
Tripper511's Avatar
Car: 1982 Trans Am
Engine: 350 4BBL
When I bought the car it already had the speedometer disconnected. A few weeks after buying the car the engine died so I bought a Goodwrench 350 with a year warrenty. But not having the speedometer hooked up voids it. Since the new engine blew I need to reattach the cable so I can get a new engine with labor included.
Old Feb 20, 2006 | 01:09 PM
Tripper511's Avatar
Car: 1982 Trans Am
Engine: 350 4BBL
I can't get the cover off the speedometer, the bolts are stripped. I found this cable on the other side of firewall, is this the speedometer cable?<P><P>Here's a pic of it in relation to the engine:
Old Feb 20, 2006 | 01:40 PM
JamesC's Avatar
Perhaps the following link will provide a bit of info:
https://www.thirdgen.org/techbb2/sho...hreadid=249244
You should be able to see where the cable enters the cabin from inside the car. The one in the pic appears to be much too high--what the heck is that plastic gizmo?
JamesC
Old Feb 20, 2006 | 01:57 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Your picture is of a vacuum line.
Old Feb 20, 2006 | 02:26 PM
Tripper511's Avatar
Car: 1982 Trans Am
Engine: 350 4BBL
Ok that link did help but I'm having trouble getting the faceplate off the speedometer. The screws are stripped. I tryed drilling a hole in the middle but nothing will grip the screw it just shaves more of it off. Any suggestions?
Old Feb 20, 2006 | 02:33 PM
Karps TA's Avatar
Car: 1985 Trans Am
Axle/Gears: 3.70
You don't need to get the face plate off the speedo. Take off the dash pad. Now reach or look behind the speedo thru the spaces in the top of the dash.
I highly doubt someone would disconnect the speedo from the gauge. I'd look at the trans first.
The speedo cable comes thru the firewall a little underneath the power brake booster.
Old Feb 20, 2006 | 03:34 PM
Tripper511's Avatar
Car: 1982 Trans Am
Engine: 350 4BBL
Karps TA You don't need to get the face plate off the speedo. Take off the dash pad. Now reach or look behind the speedo thru the spaces in the top of the dash.
Your right, no wonder that bolt didn't come off, it was just for show . After looking behing the speedo I saw that the cable was connected so it has to be at the tranny. Im going to have to wait till tomorrow so I can borrow some jack stands to get under the car. Thanks for the help so far guys!
$750 L98
Feb 1, 2025 02:25 PM
InfernalVortex
Apr 20, 2021 11:31 AM
Elephantismo
Feb 13, 2019 12:51 AM
JSDaddy189
Interior Parts Wanted
Oct 6, 2015 02:22 PM
Bigold4x4
Sep 28, 2015 05:21 PM
