How does the oil filter adapter go
Old Feb 22, 2006 | 10:10 PM
vwaltdog's Avatar
Car: 87 Trans Am
Engine: now a 350
I'm not sure what way the oil filter adapter go.
#1?
Old Feb 22, 2006 | 10:12 PM
vwaltdog's Avatar
Car: 87 Trans Am
Engine: now a 350
filter1
picture #1
Old Feb 22, 2006 | 10:17 PM
vwaltdog's Avatar
Car: 87 Trans Am
Engine: now a 350
filter2
or #2 sorry for all the posts I don't know how to post multiple pictures in one posting. Also would not having the gasket installed cause low oil pressure?
Old Feb 23, 2006 | 01:36 AM
Vader's Avatar
It probably doesn't really matter, since the valve disc is just a pressure relief/bypass, but I've seen most of them installed as pictured in the first photo.
Second question? No gasket. I just went through this myself, and was reminded that the adapter has a raised ridge of material on the back side that does any sealing that is necessary. Anything that leaks through is small enough that it is effectively "filtered" anyway. I allowed myself to hunt for that gasket, too.
As for the third question (which you haven't asked yet), 18-20 ft/lb for the bolts.
Old Feb 23, 2006 | 06:21 AM
ede's Avatar
ede
vader how long did it take you to find the oil pump gasket?
Old Feb 23, 2006 | 10:22 AM
Vader's Avatar
ede,
I finally found the adapter gaskets in my stash of old parts, along with a few new/old oil pump cover gaskets. I still haven't found those venturi bearings, though.
Don't laugh too much. Brown & Sharpe oil pumps use paper gaskets on the ground surfaces. Go figure.
Old Feb 23, 2006 | 06:57 PM
vwaltdog's Avatar
Car: 87 Trans Am
Engine: now a 350
Ok thank you
Old Feb 23, 2006 | 07:09 PM
88_Import_Slaye's Avatar
Car: 88 Camaro
Engine: 310 LG4
Transmission: 700R4 w/2200 stall
the one i got from summit has a flat side, it went towards the hole in the block. I dont see a flat side on yours so this probably does not help at all.
if the manual doesnt say, it probably doesnt matter.
Old Feb 24, 2006 | 08:09 AM
Damon's Avatar
For a factory/stock/GM oil filter adapter it doesn not matter which way you mount it. Once it pushes open the spring-loaded bypass valve the oil dumps into the same place (the middle) regadless of which side the bypass is on.
Old Jul 20, 2007 | 10:28 AM
tanager11's Avatar
Car: 91 Z28 Vert
Transmission: TKO
Axle/Gears: 3.55 10-bolt
Re: How does the oil filter adapter go
Saw this post and its somethign I am doing this W/E with my new engine.
Can you re-use those adapters & Bolts these off an old engine (my stock 305) instead of buying a new one from the "general" for a new engine I put in?
Old Jul 20, 2007 | 11:04 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Yes
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
Hotrodboba400
Dec 10, 2019 07:07 PM
FtrSpeedy
Sep 7, 2015 12:11 PM
89 formula TPI
Sep 7, 2015 11:06 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
