Just Found A Cool, New Use For SeaFoam
Car: 91 Camaro RS
Engine: 305 TBI
Axle/Gears: 2.73 Posi w/Disc
Found an exhaust gasket leak with the stuff. I warmed up the car to 220*, ran ~3/4 can through the brake booster line. Slowly poured the rest through the throttle body until the engine died. Let sit for 30 minutes. Came out and noticed white smoke from the engine. You could see it all around the cyl #2 exhaust port gasket. Now I know why my clothes smell like exhaust whenever I drive.
Car: 1983 G20 Chevy
Transmission: 4L60
Re: Just Found A Cool, New Use For SeaFoam
Car: 91 Camaro RS
Engine: 305 TBI
Re: Re: Just Found A Cool, New Use For SeaFoam
Originally posted by Fast355
Could you not hear it prior to this. FIX IT ASAP, if your clothes smell like exhaust, the fumes are getting into the car with you. Carbon Monoxide can be DEADLY! I know someone that was almost poisoned to death in a 68 VW Beetle.
And rx7speed, never heard that one. Perhaps I should pay more attention.
Car: 2005 BMW 545i
Engine: 4.4L N62B44
Transmission: 6spd auto
Axle/Gears: Rotating
with how many post go through this place it woudln't be a shock. hell I miss a lot.
on the rx7's though it was a common fix for a lot of people to put ATF and let it sit in the motor overnight to help clean the carbon. sad thing is as you said with sea foam it finds every leak. some you know you had some you didn't know. some you couldn't even hear but it knows they are there. with the ATF you will know you have exhuast leaks for the first 5 min after that you will think the car caught fire, then you will soon forget that you had a car and instead wonder why there is a huge white cloud sitting in front of you for the next 30 min or so.
Car: 1983 G20 Chevy
Transmission: 4L60
Car: 91 Camaro RS
Engine: 305 TBI
When I started the engine to clear out all the old SeaFoam, that exhaust leak spewed white clouds of smoke and the exhaust pipe was much, much worse. I slowly revved up to 3000RPM and helt it for ~15 seconds. The noise got people's attention and everyone around looked really nervous when they saw the cloud coming from my car. hehehe...
Car: 91 Camaro RS
Engine: 305 TBI
I have done the water trick every 10,000 miles or so, but I wanted to try something else since I'd never used it before. It was $5 and the next time I'll be pulling the heads so it is probably a one-time deal anyway. A good side effect is finding my exhaust leak. I wasn't even looking for it because there were other more serious issues at hand. It goes on the list to be worked out when I have the resources to do so.
Hotrodboba400
Dec 10, 2019 07:07 PM
rudolphschenker
Sep 4, 2015 02:41 AM
IROCZDAVE (88-L98)
Sep 2, 2015 08:49 AM
IROCZDAVE (88-L98)
Sep 2, 2015 08:43 AM
