Best way to spend 2 grand on an LG4
Car: 1982 Trans Am
Engine: LG4
Transmission: 200C
Axle/Gears: 3:73
I'm just throwing out ideas. I'm not actually going to put 2 grand into my 82 anytime soon.
Lets say the goal is to drop the et the most, but still be able to be daily driven.
Car- 82 Trans Am MSE
305 LG4, Open Element, 1 5/8 inch headers, 3 inch cutout,
200C three speed, stock stall,
3:73 Rear
16x8 Formula Wheels, Indy 500 245/50/16s
Et-15.9 @ 8X mph
Things that come to my mind are either a cheap crate 350, stall, and drag radials. Or a TPI fuel injection system with drs.
3:73 Rear
Et-15.9 @ 8X mph
Car: 86 coupe
Engine: 383
Axle/Gears: 9 bolt 3.27 posi
how about a set of 64cc heads,and a used 6-71 blower?
you really wouldn't mind that big hole in your hood would you?
besides,the sooner you grenade the 305,the sooner you can build that 383 you've been wanting!
Eric B
Eric B
Car: 1983 G20 Chevy
Transmission: 4L60
Originally posted by Formula350Scott
Spend it on one of your other 3 f-bodys. J/K
Convert it to TPI and turbo it.
Car: 1982 Trans Am
Engine: LG4
Transmission: 200C
Axle/Gears: 3:73
The rest of the cars are my dads. Only the 82 is mine.
Yea, I've thought about it that way.
A turbo would run quite a bit of money. The cheapest route would be a custom rear mount. Depending upon how much boost, once the injectors/pump/lines are past there limit, the price starts to stack up. Plus the cost of a chip.
Where do you buy a GM 2 bar map from?
Originally posted by Fast355
Put a blow-through supercharger carb on it and turbo it.
My advice is dont buy anything 305 specific. Anything you get, make sure it'll work good on a bigger engine so you dont end up with spare parts you cant use and have to sell off if you put a 350+ in it later.
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
buy the 350 vortec combo and toss a cam in it. or buy the $1300 longblock from GM, sell the heads on ebay and toss vortec heads on it with a cam. putting money into the 305 is worthless in my opinion, and i've gone down that route with a low 13 second 305 at the track.
Transmission: 4L80E/4L80E
4" bore kit.
305 heads with the "usual" working over.
A good cam.
TH350 (the TH200C will never hold up, at least not as well as a TH350 with the same money in it).
A good cam.
Car: 87 IROC
Engine: 406 sbc with Trick Flow heads, Hook
Transmission: Pro built 700R4
Axle/Gears: waiting on a new rear!!!!
Buy a 350 short block on ebay for right at a $1000 shipped I've found 3 or more sellers that make them with quality parts. There is also two sellers that sell upgraded vortec heads with bigger springs and valves for $599 shipped. Voodoo cam with lifters $189 ebay. Air Gap crosswind intake $135 ebay. $35 timing chain ebay etc. etc. If this car doesn't have to pass emissions go carb.
Car: 1982 Trans Am
Engine: LG4
Transmission: 200C
Axle/Gears: 3:73
Originally Posted by Stekman
Is a 350+ out of the question?
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
I converted my LG4 from this
Edelbrock 1406 Carb, Edelbrock 7101 hi rise intake, Edelbrock 14x3 Air cleaner with K&N air filter,
to this, 87 TPI setup with 87 TPI heads convrted to a 90-92 Speed Density system, Crane Cams powermax 2050 Cam, SLP Dual CAI, 52mm TB, dynomax shorties with custom y-pipe and 3" Pacesetter Cat Back, MSD 6A with Blaster 3 coil, and some other minor stuff. Made the car a whole new beast.
here is a vid, http://www.transamws6.com/video/ZepherWS6.mpg
Car: 1982 Trans Am
Engine: LG4
Transmission: 200C
Axle/Gears: 3:73
Yea, I remember reading through your website Zepher, and thinking I shouldn't spend money on the carb and intake, just go straight to the TPI.
I like all of the data you have on your website.
HoosierinWA
Oct 7, 2015 10:15 AM
