Car stalling Problem
Old Mar 19, 2006 | 02:37 PM
Z288Iroc's Avatar
I have posted this in other forums if it looks familiar
I have been without my baby now for 1 week
The car (91Z 305 TPI) will start and randomly stall at different temp, distances even at idle in the parking lot. After stalling it wont resart untill I give up and try again later. While attempting to start I hear a ticking coming from fuel pump relay.
These are the parts I have changed in order
Fuel Filter
Fuel Pump
Ignition Module
Map Sensor
Fuel pressure Regulator
and today Fuel pump relay (still ticks when trying to start)
If I spray some starter fluid into the throttle body it will help to start it but then it will stall, also I have checked the plug wires and they have spark.
Im at a loss and will forever be in debt to the person that can help me with this one , Its my only car and I have to borrow my moms just to get to work. Any help and I will appriciate it forever. Thank you
Old Mar 19, 2006 | 02:51 PM
DENN_SHAH's Avatar
Car: 83 POS monte carlo 2015 chevy P/U
Engine: 92 5.7 tpi 5.3
Transmission: 700r4 6L60E
Axle/Gears: 2.42 too high
with it starting with a shot of starting fluid the ignition is probably ok. although i don't recommend using starting fluid, its hard on the motor.
does it have any codes?
when it won't start, you need to check your fuel pressure, spark, & injector trigger.
if they check good its time to hook up a scanner.
Old Mar 19, 2006 | 07:16 PM
Z288Iroc's Avatar
i think i got it. when I unplug the Throttle Position Sensor the car starts and stays running, although at very high rpms, new one coming in tomorrow $45 at advance, hopefully this will solve the long week of fustration and being w/o a car. thanks for the help
Old Mar 19, 2006 | 07:48 PM
Red Devil's Avatar
Car: Tree Huggers
Engine: Do Not
Transmission: Appreciate Me.
First thing you should do is pull your codes.
Wade787b
Sep 29, 2015 01:15 PM
TreDeClaw
Aug 14, 2015 06:58 PM
Tony Ferrarri
Aug 11, 2015 07:59 PM
Fronzizzle
Aug 9, 2015 01:15 PM
