Please help w/my no start problem
Old Mar 24, 2006 | 04:57 PM
mantiz85ws6's Avatar
Car: 85 Trans Am
Engine: 350 T.P.I.
Transmission: WC T-5
Things I have checked
fuel pressue good at 40 psi
fuel pump is priming I can hear it come on
bought a spark tester and tried a couple of wires 1 got a little spark the other no spark, also can anyone explain why my fan turns on now when I turn the key to the on position?? this started with the no start problem.
Visually checked all the under dash fuses all appear to be fine and not blown.
Old Mar 24, 2006 | 05:16 PM
DLV555's Avatar
Car: 1987 Monte Carlo SS
Engine: 400 SBC
Transmission: 200-4R
Axle/Gears: 4.10
Well you said you have weak spark at some plugs and none at others. You have already narrowed the search down. It's an ignition problem. Check the coil output with your spark tester, if it is healthy then you may just need a tune up. If it has been a while since you have done a full tune up, then now's your chance. Check your cap and rotor, they may be worn out, if your wires are old an nasty replace them, and if your plugs are fouled up and over gapped get new ones. If the coil output is bad, then you likely just need a new coil. It wouldn't hurt to have the ignition module tested, parts stores can do that, and check the resistance on your pick-up coil. I don't know the specs, but maybe someone does.
Old Mar 24, 2006 | 05:25 PM
Car: 85 Trans Am
Engine: 350 T.P.I.
The wires are brand new
The spark plugs are brand new
The cap, rotor, new
I am running an hei big cap set up 1985 tpi
not really up to par on ignition stuff is the ignition module under the cap? Anyone have a picture of one for reference
Old Mar 24, 2006 | 05:45 PM
DLV555's Avatar
Engine: 400 SBC
Axle/Gears: 4.10
Attached is a picutre of the ignition module. It is the breaker for the primary ignition circuit, just like points in an old school distributor. It is under the cap at the back of the distributor. The pick-up coil is the triggering device that tells the module when to remove the ground for the primary ignition. If that makes any sense.
Attached Thumbnails Please help w/my no start problem-acc-35370_w.jpg
Old Mar 24, 2006 | 07:33 PM
Car: 85 Trans Am
Engine: 350 T.P.I.
is this module the same in the coil in cap style?
Old Mar 24, 2006 | 10:30 PM
DLV555's Avatar
Engine: 400 SBC
Axle/Gears: 4.10
Well that one pictured may not be yours since you have an '85, but it is similar. But if you are asking if it is there at all in a coil-in-cap style distributor, then yes it is.
Old Mar 25, 2006 | 10:43 AM
Car: 85 Trans Am
Engine: 350 T.P.I.
Well I removed the ignition module and took it to get tested it checked out fine. What next??
Old Mar 25, 2006 | 11:26 AM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
When you unplugged the IM, there was a 2 wire connector to it, that goes to the PickUp coil,it "wraps" around the dizzy shaft, but look at the connection and the PU coil to see if you see any green crud/oxidation on it and the plug connection, if so replace it...you'll have to pull the dizzy, knock the rollpin out of the gear and slide the shaft out.
Between the two connections going to the PU coil, should OHM out to 800 ohms, plus/minus 50 and be stable when you wiggle the wires.
On another note, the "test" at the AP stores is not always accurate on the IM's.
92camaroJoe
Jul 29, 2023 07:57 PM
Infested
May 22, 2018 11:56 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
92camaroJoe
Aug 13, 2015 06:07 AM
mustangman65_79
Aug 8, 2015 12:07 PM
