Θ Please, Opinions Θ
Old Mar 30, 2006 | 07:28 PM
Brandons'86T/A's Avatar
Car: 86 t/a
Engine: 77 chevy 350
Transmission: stock
Axle/Gears: stock
ok i got a 86 trans am with a 77 chevy 350 in it, when the gas tank is near empty it runs great, but then i dump only 5 dollars of gas in it, and all the sudden it runs like udder sh*t, maybe the gas tank needs cleanin, maybe Carb, Maybe fuel pump, PLEASE POST NE AND ALL OPINIONS!!!!!!!!!!!!
Old Mar 31, 2006 | 01:45 PM
Car: 86 t/a
Transmission: stock
Axle/Gears: stock
Please and thank you, please send me some opinions to work from, THanks sry bout last post that was here, i was in bad mood pissed off at the car lol..
Old Mar 31, 2006 | 02:23 PM
Slow89Iroc-Z's Avatar
Car: 1989 Iroc-Z
Engine: 350ci SBC
Weird....
Old Mar 31, 2006 | 02:29 PM
mw66nova's Avatar
Car: camaro sportcoupe
Engine: 7.0L
Transmission: G-Force GF5R
Axle/Gears: Moser 9"
instead of demanding an answer, why don't you ask nicely, maybe one of us who has had experience will kindly answer your questions.
Old Mar 31, 2006 | 02:50 PM
gp423's Avatar
Car: 1989 Firebird Formula
Engine: LB9 305 tpi
Axle/Gears: open 2.73's baby!!
Well the car is just about 20 years old, i doubt someone cleaned out that tank. my oppinion is when u put the $5 of gas in, ur mixing the gas with the crap at the bottom of the tank, probably clogging the fuel filter a bit, causing your car to run bad. thats my best guess.
Oh yea, and have some dam patients(cant spell), this forum is awesome and people respond very fast, just dont be a jerk while posting.
Old Mar 31, 2006 | 05:20 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
usually when the tank is low it'll run crappy, 'cuz it's picking up junk. chances are it's doing that now.
dropping the gas tank will be a last resort.
change your fuel filter at the carb. fill the tank up past half. shake the car a bit (can't hurt right?) run it. if it won't run right, kick yourself for putting so much gas in, siphon it into jerry cans, and drop your tank and rinse it out. clean/replace your pickup sock.
run a can of seafoam into your tank. (or 1/3 can). meanwhile run another 1/3 into the intake. (follow instructions on bottle). (coincidence there are 3 uses, and each takes 1/3 of the can ? )
those are my thoughts and ideas.
Old Mar 31, 2006 | 05:36 PM
Car: 86 t/a
Transmission: stock
Axle/Gears: stock
Ok, Thank you very much, Oh, and i did Replace the fuel filter near Carb, and the place u put gas in, u can wiggle it a lil bit, but when it stops rain'n ill get it jacked up and take a look under there, and prolly just cyphon it right from start, and clean tank out, and check intake, might it be the fuel pump? at all?
Old Mar 31, 2006 | 05:48 PM
Rob Wade's Avatar
Car: 89 jaguar xjs convertable
Engine: 89 L98 5.7 TPI
Axle/Gears: 3.23 dana 44
And stop yelling!
Old Mar 31, 2006 | 06:10 PM
Supervisor42's Avatar
Car: 1988 Trans Am GTA
Engine: 350 4BBL
I'll echo stop yelling also. Here's something to check. The charcoal canister emissions system. It is the only thing affected by the act of putting gas in the tank. Temporarily disconnect & plug the vacuum hoses to the canister. It's possible that the problem is the engine is picking up either vapor or raw gas at idle and filling the tank refills the "supply" of vapor/gas being picked up by the engine. I changed my CC car to carb and was trying to figure when to trigger the solinoid that evacuated the charcoal canister. No problem, I'll just tie it in with the Torque converter clutch and since the car is at highway speed it will just "trickle in". Boy was I wrong. Choked the engine so bad it was missing more than it was running.
p.s. still looking for the NE (north east) opinion.
Old Apr 4, 2006 | 02:19 PM
Car: 86 t/a
Transmission: stock
Axle/Gears: stock
T T T
Pac J
May 17, 2020 10:44 AM
LiquidBlue
Wheels and Tires
32
Dec 10, 2019 04:06 PM
cheesehomer
Dec 31, 2015 08:48 AM
skinny z
Oct 5, 2015 06:23 PM
Jlanz55
Sep 29, 2015 08:55 AM
