Spark plug indexing
Old Mar 31, 2006 | 09:40 PM
vorgath's Avatar
Car: 1991 Camaro RS
Engine: LO3
Axle/Gears: 3.42 LS1
Spark plug indexing
indexing washers, two kits available from Moroso
Part No. 71900
Moroso Spark Plug Indexing Washers: Tapered Seat, .010", .021", .032"
Part No. 71910
Moroso Spark Plug Indexing Washers: Flat Seat; .043", .050", .064"
Which one ? It's for a LO3, stock swirl port heads.
When I tighten them, will I still be tighteningf them to torque specs, or will the washers affect that, so I'll only be able to go hand tight plus a tiny tiny bit more ?
Old Mar 31, 2006 | 09:57 PM
Jza's Avatar
Jza
We have tapered seats.
Old Mar 31, 2006 | 10:07 PM
vorgath's Avatar
Car: 1991 Camaro RS
Engine: LO3
Kewlness, QUICK reply.
Old Mar 31, 2006 | 10:38 PM
ljnowell's Avatar
Part No. 71900
Part No. 71910
I dont mean to sound like a jerk, but why waste time and money indexing spark plugs on a stock lo3?
Old Mar 31, 2006 | 10:51 PM
robertfrank's Avatar
Car: 1988 camaro "SS"/ 1991 305/T5
Engine: 383 LT1 in progress/LT1TBI 355 soon
Transmission: Probuilt 700R4 3600 stall/ T5
Axle/Gears: Moser axles, 3.42 Eaton Posi
because EVERY little bit helps with these engines.I would like to know more about this as well.from what i have read you can gain as much as 5hp with the plugs properly indexed along with improved throttle response and mileage.
Old Apr 1, 2006 | 08:14 PM
vorgath's Avatar
Car: 1991 Camaro RS
Engine: LO3
Indexing alone may not be worth 5 hp, however grinding down the electrode slightly, double checking the gapping and indexing all together may do something.
Should the opening be towards the exhaust valve, intake valve or simply in between ?
Old Apr 1, 2006 | 08:19 PM
Jza's Avatar
Jza
The idea is to face the opening away from the intake valve so that the intake stream doesn't "blow" out the spark or wet the plug when there's an excessive amount of fuel entering the chamber.
Old Apr 2, 2006 | 12:35 AM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
Use a sharpie to make an index line. The idea behind indexing isn't so much to avoid blowing the plug out as it is to avoid shrouding the spark, exposing the mixture to the fullest possible spark.
I agree with LJ, though.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
db057
Apr 28, 2019 07:45 AM
Ranbo108
Sep 9, 2015 12:20 PM
Jlanz55
Sep 9, 2015 09:09 AM
89 formula TPI
Sep 7, 2015 11:06 AM
