Hooking up msd 6a question
Old Apr 3, 2006 | 02:22 PM
1985WS6transam's Avatar
Car: 1988 Firebird Formula
Engine: 388 Carb
Axle/Gears: 4.10
I am currently in the process of hooking up my 6A box in my car. It is a 350 with a carb and an in cap HEI distributor. I ahve the 4 pin module, attached is the wiring diagram they have for it. In the atttachement it says:
NOTE: The GM Ignition Module is removed and replaced with the MSD PN 8861 Wire Harness
Do i need to take out my ignition module in order to hook this up? I dont get it. Some one with experience please help. Also I dont have PN 8860 do I need to get it or can i splice wires together and hook it up?
Old Apr 3, 2006 | 02:51 PM
Bobbyz's Avatar
Car: 87 IROC Z "ZZ4"
Engine: 350 "ZZ4"
Transmission: ck performance th400 3000 stall
Axle/Gears: 3:73 10 bolt
i had to take it out and replace it im not sure if there's another way to do it
Old Apr 3, 2006 | 03:47 PM
Engine: 388 Carb
Axle/Gears: 4.10
So is all of this worth it? do you feel a performance gain? do these boxes really work?
Old Apr 3, 2006 | 04:18 PM
Bobbyz's Avatar
Engine: 350 "ZZ4"
I really could'nt tell ya how much of a gain there is if any i still have to give it a good tune.
Old Apr 3, 2006 | 08:08 PM
z282slo's Avatar
Car: 91 z28
Just did this last weekend to a friend's truck, yes you need that part it should have come w/ your box, and yes it's worth it expecially on a carb it will start much faster and idle cleaner and smoother. By the way when I put mine on my camaro it cleanded up the idle so much the idle went from 800 to 1100!
Old Apr 3, 2006 | 08:27 PM
Engine: 388 Carb
Axle/Gears: 4.10
Yea, I bought mine used so i wonder if i can even get that part, I got a good deal on mine, $20 at a swap meet. I just didnt get around to looking at it till now because I am working on my car running really good now, I put in an adjustable vacuum advance as well as new springs for the centrifugal advance. I gapped my plugs at .042 and have a Accell high spark coil.
I still need good wires, rotor, and cap and hook this up then and I should have optimum ignition... I think thanks for the advice
Old Apr 3, 2006 | 11:43 PM
Bobbyz's Avatar
Engine: 350 "ZZ4"
121-8861 is the part number in jegs i believe.
Old Apr 4, 2006 | 05:37 AM
Engine: 388 Carb
Axle/Gears: 4.10
Thanks, for only $7 more i have to hook it up now... Are there any other parts I will need?
Old Apr 4, 2006 | 05:39 AM
Engine: 388 Carb
Axle/Gears: 4.10
Whoa Whoa, I am pretty sure I can make that lol it is 2 wires and some retaining clips... I just really dont want to wait for shipping. Anyone think that it is a bad idea to make it?
Old Apr 4, 2006 | 07:08 AM
OneBeast's Avatar
If you use the right size wire, I don't see what it would hurt.
Hotrodboba400
Dec 10, 2019 07:07 PM
sreZ28
Oct 22, 2015 08:21 AM
meeklay812
Oct 1, 2015 03:46 PM
raymondandretti
Sep 27, 2015 06:43 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
