clearancing block for comp roller timing chain?
Old Apr 5, 2006 | 12:00 AM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
I put in my cam tonight, and timing chain. It seems like the comp magnum double roller timing chain is going to be rubbing against the block above and right of the cam. (looking at the block from the front.)
-is there a clearance that I should be expecting? stick a .050" feeler gauge in there?
-is it normal to have to grind off a bit here? I wasn't expecting this, perhaps my cam is too far in....?
Old Apr 5, 2006 | 12:23 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
It's pretty normal, just take a die grinder and knock down the high spots. There's not much growth or wear in that direction at all, so as long as there's "enough" clearance it should be good.
It's hard to see through the paint, but you can see where this block is clearanced for the timing set.
Attached Thumbnails clearancing block for comp roller timing chain?-03430023.jpg
Old Apr 5, 2006 | 11:24 AM
Sonix's Avatar
Car: 1982 Trans-Am
aces, thanks. I can't tell much from that pic though...
I guess i'll remove the cam sprocket, and cover the cam, and hope I don't slip and nick the end of the cam, or get shavings there.
I guess i'll try a die grinder and stone, and remove ~1/8" and retry.
Old Apr 5, 2006 | 07:56 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
A carbide burr will be a lot nicer to use than a stone.
Old Jun 12, 2006 | 09:01 PM
hoogabooga's Avatar
Car: '68 corvette '73 Corvette
Engine: 427 454
Transmission: TH400
My cloyes dbl. roller is rubbing there at the 3 oil holes. is it ok to grind there?
Old Jun 12, 2006 | 09:28 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Yup
Old Jun 12, 2006 | 09:33 PM
hoogabooga's Avatar
Engine: 427 454
Transmission: TH400
thanx,
Old Jun 12, 2006 | 09:50 PM
Seems to be pretty common on newer blocks... they must be leaving more metal around there than they used to. Didn't ever used to be a problem. Now it happens all the time.
Vintageracer
Jan 10, 2020 05:33 PM
midge54
Dec 27, 2019 04:14 PM
camaro71633
Sep 1, 2015 10:24 AM
MY87LT
Aug 17, 2015 08:43 AM
anesthes
Aug 8, 2015 09:37 PM
