Clicking, Front of engine, Right side
Old Apr 6, 2006 | 01:03 AM
camarosource's Avatar
Car: Custom 1992 Camaro Z28 25th Anniver
Engine: 5.7L V8 350 L98 TPI
Suddenly there is a clicking sound while the engine is running. I've narrowed it down to something on the Right side on the front of the engine.
A pulley? Doesn't sound like alternator.. Could the belt be too tight? There is literally NO PLAY at all.. it's on TIGHT.. is that normal?
Old Apr 6, 2006 | 02:04 AM
GuitarJunki17's Avatar
Car: 1990 IROCZ Camaro
Engine: 350 4bbl, 200cc Heads, 270hr Cam
Transmission: 700R4 w/ Trans-Go shift kit.
Axle/Gears: GM 10 bolt Posi
Your belt system works with a tensioner, which adjusts the tension for you, so most likely it is not a belt.
Usually, a clicking is the result of an exhaust leak at the point where the header meets the head. This is generally harmless and is fixed by simply tightening the header down to the head. Another, less common, but probable cause of the ticking you hear could be a rocker arm that has come a little loose. Check your pullies to make sure that they do not wobble AT ALL while the engine is running. Basically, they should be so straight that when the engine is running, you shouldnt be able to tell that they are rotating.
Terrell351
Jun 13, 2021 01:13 PM
B_Dubya
Aug 26, 2015 05:09 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
wruiz
Aug 11, 2015 02:59 PM
