How to change cap & rotor?
Old Apr 8, 2006 | 06:02 PM
stingerssx's Avatar
Car: '88 Firebird Formula 350
Engine: Built 383 TPI
Transmission: Built 700r4
Axle/Gears: 9 bolt, 3.27:1 Posi
That got your attention, didn't it!!
You thought that I was serious huh?
Well unfortunatley, I am!! My problem is that I have gigantic hands, (being 6'4") and no room to work! But then again, no thirdgen has any room at all anyways.
Here's the story. I bought plug wires, cap, & rotor, and found that my hand doesn't fit between the firewall, and the cap (to reach the rear screw). Also, the screw driver is too long to fit. It hits the top of the firewall. I have a minimal amount of tools right now, (due to an argument), so I would loosen up the dist. bolt, and turn the rotor, but I hope that I don't have to do that.
How do you guys get at that screw?
Btw, I have the stock TPI intake.
Old Apr 8, 2006 | 06:54 PM
BlkBird408's Avatar
Car: 89 Firebird
Engine: 408
Axle/Gears: 12 bolt/4.11
I bought a short screwdriver so I can reach back in there and get to that screw. Before that I always just loosened the bolt and turned the distributor so I could get to it!!
Old Apr 8, 2006 | 06:57 PM
CamaRod's Avatar
Car: 91 Camaro RS
Engine: 305 TBI, (right now)
I got this little short skinny screw driver with this crapy electrical wiring tool set
its a perfect fit
Old Apr 8, 2006 | 07:07 PM
1985WS6transam's Avatar
Car: 1988 Firebird Formula
Engine: 388 Carb
Axle/Gears: 4.10
I found a random S shaped screwdriver, fits perfect...
Old Apr 8, 2006 | 07:14 PM
xlwhellraiser's Avatar
Car: 1992 Trans/am convertible
Axle/Gears: 2.73 drum WS6
Or get someone like a GF, a freind a kid... to tighten it up for you. Unless you can get the dist. back where it was I would not move it. Just get a lill screw driver and you'll be fine.
Ya know, big hands big feet... Big socks
Old Apr 8, 2006 | 07:49 PM
Dialed_In's Avatar
Car: '88 IROC-Z medium orange metallic
mark the distributor housing and manifold, twist the distributor to get to the screw and replace the cap/rotor. When you're done line up the marks then set timing with a light.
Old Apr 8, 2006 | 07:50 PM
stingerssx's Avatar
Yeah, my girlfreind offered to help, (that's why I love her!!) I was trying to use a stubby, but the grip is too fat. Then the one that is the perfect length, the tip is too small for the screw. But I should get a screw driver for this job only. I'll save it for only cap & rotor jobs! I guess that I need to go to Harbor Freight tonight!!
Thanks for all of the help.
Old Apr 8, 2006 | 10:23 PM
Red Devil's Avatar
Car: Tree Huggers
Engine: Do Not
Transmission: Appreciate Me.
Flex shaft. Makes life easy.
Old Apr 8, 2006 | 11:43 PM
thirdgen88's Avatar
Car: 1995 Corvette
Transmission: 6 spd Manual
Axle/Gears: Dana 44, 3:45:1
I'm with Red Devil on this one... I have a flexible shaft 1/4" driver (made by Stanley, got it at Wal-mart surprisingly enough).. That thing is friggin' awesome. If you have the divorced coil (small cap) HEI setup, you can use one of those flexible drivers with a 5.5mm socket to loosen the distributor cap screws.
Old Apr 9, 2006 | 06:55 PM
Tremo's Avatar
Car: 88 IROC-Z - original owner!
Engine: LB9 with K&Ns, MSD, Foil, Taylor
Transmission: WC T-5
Axle/Gears: BW 9-bolt, 3.45 posi
Hey man, I'm 6'3" with big hands, and I have no problem at al changing my cap and rotor, module, the whole dizzy, whatever. Use a short screwdriver.
eightsixseven
Dec 16, 2024 01:50 PM
Infested
May 22, 2018 11:56 PM
Ron U.S.M.C.
Sep 7, 2015 08:38 AM
drewdock87
South Central
Aug 18, 2015 09:02 PM
cstrobel65
Aug 15, 2015 10:19 AM
