FASTEST LO3 or 305
Old Apr 10, 2006 | 04:08 PM
pyro719juggalo's Avatar
Car: 1989 RS
Transmission: t5
Axle/Gears: 373 locker
FASTEST LO3 or 305
Who has it and what parts and mods did you do?
Old Apr 10, 2006 | 04:32 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Tim burgess, nitrous. 11.xx time, TPI 305
Or mwnova66, 13.05, NA. 4bbl 305.
LO3's aren't fast.
Old Apr 10, 2006 | 04:40 PM
Token's Avatar
Car: 1992 Firebird
Engine: forged 357
Transmission: 700r4, 2200-2400 stall, vette servo
Axle/Gears: stock pegleg 2.73 drum (temp)
Originally Posted by Sonix
LO3's aren't fast.
Old Apr 10, 2006 | 04:52 PM
Car: 1989 RS
Transmission: t5
So the LO3 is not worth building into a performance engine? And Why?
Old Apr 10, 2006 | 04:58 PM
Token's Avatar
Car: 1992 Firebird
Engine: forged 357
Not at all. Take it from someone who has tried- like me. I spent less money building a mild 350 than I spent on my 305 to have less than 300 horsepower. You will regret modding a 305, I can promise you. A lot of people don't feel like pulling an engine and swapping a new one in- that's fine... but modding the 305 you might as well throw your money in the trash can. You'll be in the 14s at best unless you have some SERIOUS cash. Save yourself the struggle, start with a better platform.
Old Apr 10, 2006 | 05:02 PM
90FormulaWS6's Avatar
Car: 1991 Camaro RS
Engine: 305 TBI
Transmission: WCT5
Once i get my gears installed, I should be mid 13s w/ TBI, this all for under $1700.
edit go to my profile for mods.
Token's Avatar
Car: 1992 Firebird
Engine: forged 357
Here, look at my signature. It would be longer but I wasted $1500 on a stupid 305 TBI.
Old Apr 10, 2006 | 05:08 PM
Car: 1989 RS
Transmission: t5
yea it sounds like id be better off with a 350. I just thought if I added a zz4 cam in take and carb I would be around 300hp Guess not!
Old Apr 10, 2006 | 05:13 PM
Car: 1991 Camaro RS
Engine: 305 TBI
Transmission: WCT5
well you might be around there at the flywheel, but your gonna need to do a whole lot of tuning to get it all out of it. ive been tuning my car for 5 months off and on and its still not perfect, but then again i dont think ill ever be satisfied with the tune.
Unless you hell bent on doing something truly unique to your 305, then id suggest going for a 350 because its easier.
Old Apr 10, 2006 | 05:17 PM
CreepingDeath94's Avatar
Car: '87 Trans-Am
Engine: LB9 (305 TPI)
Axle/Gears: 3.42 or 3.73..figuring it out still
I think the problem lies in trying to mod a 305 TBI...I think you can get some fast times with the TPI setup on it and not spend too much more than you would changing to a 350 and modding it...
Old Apr 10, 2006 | 05:18 PM
Car: 1991 Camaro RS
Engine: 305 TBI
Transmission: WCT5
This isnt true, TBI can be as fast or faster than TPI.
Old Apr 10, 2006 | 05:23 PM
Car: '87 Trans-Am
If thats the case, then you should be able to make a killer 305 with either application without spending a boat load of money. I just dont know much about the TBI setup. I dont believe in the 305 bashing that usually goes on either though...
Old Apr 10, 2006 | 05:25 PM
Car: 1991 Camaro RS
Engine: 305 TBI
Transmission: WCT5
i agree, with the correct mods and the correct tuning the 305 can be made to perform regardless of induction
Old Apr 10, 2006 | 05:27 PM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
15.20s @ 95ish in a 5,300 lbs Fullsize Van with a 312 (.040" over 305), heavily ported 081 TPI heads, BIG crane retrofit roller cam, Holley Projection/Edelbrock 3704 manifolds (2" bores on both), 454 TBI assembly, 68 lb/hr injectors at 32 PSI, VAFPR, lots of prom tuning, 1 7/8" X 3" headers, 3" dual exhaust, 2,800 stall in the built 700r4, 3.73 gears, P295/50/R17s.
I had maybe $600.00 into the long block making 300 RWHP.
It needed less cam, more gear and possibly more stall. To me it was a dog out of the hole. But then again 5,300 lbs is not easy to push from a dead stop either.
Old Apr 10, 2006 | 05:28 PM
Mcdamit's Avatar
Car: 89' Iroc-Z G92
Engine: TPI 305 G92
Axle/Gears: Limited 9 bolt, 3.45
Fastest a TPI305 will break is a high twelve completely N/A. Its gonna cost ya,, and your gonna spend alot of money doing it.
You would need off the bat.. New Injectors, an adjustable fuel pressure regulator, a ported plenum, a ported baseplate, ported large tube runners, headers, exhaust, rear end gears (3.45's work nice for the 305's powerband), at least a 268/272 cam, heads with 1.94 valves and 1.55 exhaust, 10:1 pistons, and a full computer tune, manual transmission obviously.
That will shutup an LSX.
Old Apr 10, 2006 | 05:47 PM
Car: 1989 RS
Transmission: t5
Im doing away with all the emissions junk and the computer and putting a carb on. If the 305 isnt fast then I can tranfer all my mods to a 350 later. I am going to run a 150 shot on it.
Old Apr 10, 2006 | 09:07 PM
urbanhunter44's Avatar
Car: '72 Chevy Nova
Engine: Solid roller 355
Transmission: TH350
Axle/Gears: 8.5" 10-bolt 3.73 Posi
For maybe 660 feet.. after that any TPI setup is going to get trashed by an LSx motor.
Old Apr 10, 2006 | 09:09 PM
Token's Avatar
Car: 1992 Firebird
Engine: forged 357
those heads would hold you way back... as well as your poor displacement.
Old Apr 10, 2006 | 09:20 PM
sasser43's Avatar
Car: 89 GTA
Engine: 350 TPI L98
TPI's hold their own down low, up top is a different story.
Old Apr 10, 2006 | 09:22 PM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
He did not mention a stock TPI piece in that list, IIRC. The aftermarket is there for TPI with the right $$$.
Old Apr 10, 2006 | 09:31 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
If Fast355 were to have put his 312 combo into an f-bod it would have the potential to run low 13's. JPrevost ran a 13.5 with his TBI vortec 350 and had a slipping trans. Lo-tec ran a 13.5 with his swirl port headed and LT1 cammed LO5.
Dewey316 ran a 14.5 with a cam, tuning, 3.42's and headers. That doesn't sound worthless to me for $1000 in mods. He then ran a 12.9 with a small shot on top of that combo.
People who throw parts at a TBI set-up and fail to do the necessary ECM work all come back crying and claim TBI is junk. Granted it is not intended for all out performance (best suited for a DD with economy and emissions in mind) it isn't worthless (per Dewey's and Fast355's results). That is unless you feel dropping more than a second off your ET for only $1000 is worthless.
The best LO3 times have yet to be seen. TGO has unlocked a tuning crowd that has figured these cars out. TBI cars are unique in that power is made in the chip. Certain parts will make it "theoretically fast by hot rod standards" but without the chip work the set-up isn't going anywhere. Stay tuned because many people on TGO are about to eat their words.
Old Apr 10, 2006 | 09:38 PM
sasser43's Avatar
Car: 89 GTA
Engine: 350 TPI L98
Yes but i was referring to urbanhunters post who was referring to Mcdamits post. If that makes sense. Mcdamit gave a list of mods to a 305 TPI that would "shut a lsx up"
Old Apr 10, 2006 | 09:45 PM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
I have to wonder what it would have done in my G20 with a 60' of less than 2 seconds. My fastest was a sundial slow 2.18, ETs were correspondingly high, but my trap speeds were in the mid 90s though!
I agree with you word for word.
Old Apr 10, 2006 | 09:51 PM
Car: 1991 Camaro RS
Engine: 305 TBI
Transmission: WCT5
shiftys got it down to a T
Old Apr 10, 2006 | 10:16 PM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
I ran both my G20 and a theoretical Camaro RS through Car Test using DD2003 number of my HO LO3. Keep in mind the van ran the following
0060' = 02.18
0660' = 09.93 @ 74.7
1320' = 15.23 @ 95.4
Here is the simulation of my G20, 5,300 lbs, 3.73 gear, P295/50/R17s, 2,800 stall, launch at 1,200 to keep from burning the tires (thats what I launched at), the simulation predicted light wheelspin (which there was in real life)
0060' = 02.21
0660' = 10.03 @ 75.8
1320' = 15.32 @ 92.7
The simulation predicted 21 MPG Highway, I was able to get 19+.
Now insert the same driveline into a 3,550 lbs 1990 RS Camaro with 3.23 gears, 2,800 stalled 700r4, P245/50/R16s, 800 RPM launch (simulates lighting the tires up) LOTS of wheelspin showing in the simulation.
0060' = 02.14
0660' = 09.01 @ 87.8
1320' = 13.32 @ 106.3
The simulation predicts 26 MPG highway.
I guess bottem line is there should be a low 13/ high 12 second pass out of a NA 305 powered F-Body with reasonable street manners.
Old Apr 10, 2006 | 10:51 PM
sasser43's Avatar
Car: 89 GTA
Engine: 350 TPI L98
Wow, thats a cool program. I knew they had ones that predicted the ET but i didn't know it predicted things like wheel spin.
Old Apr 10, 2006 | 11:10 PM
Sonix's Avatar
Car: 1982 Trans-Am
I still gotta wonder....why? 295 17's on a VAN??? I saw the picture you posted of it a while ago, didn't have 17's that I noticed.... either way....
Old Apr 10, 2006 | 11:12 PM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
Because I needed tires and wanted a new set of wheels at the same time. Really made the van handle and grip alot better. I have alot more confidence in slick rainy weather now.
The picture had 255/70/R15s on the stock sized 15" wheels. It now has P295/50/R17s on17" Impala SS rims(5 on 5" pattern).
Old May 12, 2006 | 02:20 PM
Rally Smith's Avatar
Car: 91 RS
Engine: 305 TBI
Axle/Gears: Factory 2.73 (unfortunately)
You can always stroke it.
Chris 335 Camaro
Old May 12, 2006 | 06:35 PM
mw66nova's Avatar
Car: camaro sportcoupe
Engine: 7.0L
Transmission: G-Force GF5R
Axle/Gears: Moser 9"
it was actually a 13.03@103mph.
the 305 is going back in with a bigger cam and better heads. hoping to break 12's n/a.
also, don't forget about Willie's tt305.
Old May 12, 2006 | 06:40 PM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
also, don't forget about ******* tt305.
When did you decide this? What heads are you going to go with? I am thinking the worked 113s that you have on your current 350, combined with a nice solid roller cam. You should have NO problem running in the high-mid 12s. Especially considering the TAME cam you had in the 305 and the stock 416s on top!
I almost wish that I had bought some ZZ4 heads, worked them, and put them on my 312, I would be in the 14s instead of the 16s.
Old May 12, 2006 | 06:46 PM
mw66nova's Avatar
Engine: 7.0L
i decided it when i cracked the 350 block i'm currently using. only money i'm spending is on 1 new .030 over 305 piston, new bearings, rings, and head gaskets.
10.2:1 c/r
worked 113 heads
crane powermax solid cam 238*/248*@.050 .480"/.500" lift 114 lsa.
quick question for you fast355: i'm thinking of notching the top of the bores where the intake valves go to de-shroud them some...think it'll be worth it or just cause more trouble by adding turbulence and hotspots in the combustion chamber?
Old May 12, 2006 | 06:53 PM
sully91rs's Avatar
Car: 91 RS, 95 Z28
Engine: 305 tbi, 350 lt1
Transmission: 4l60, 4l60e
Axle/Gears: monsterous 2.73s in both
Chris 335 Camaro
How much would that cost.
Old May 12, 2006 | 07:00 PM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
10.2:1 c/r
worked 113 heads
Sounds like a good combo.
I have never tried that on a small block chevy. I do know that Hot Rod notched the bores on their junkyard 400 HP 318 that they put larger valves on. On the dyno it showed no ill effects. 2.02/1.60 valves in a 318=shrouding.
Junkyard Jewel:400hp 318 - Hot Rod
EDIT-Trying the picture again.
Then again, if you are running the stock 1.94/1.50 valve size, I see no benifit to notching the block. I ran 1.90/1.55" valves in my 312 and it was a great breather.
Old May 12, 2006 | 07:01 PM
mw66nova's Avatar
Engine: 7.0L
the kits are available through Powerhouse and i want to say they are around $700 total if you get it with balancer and flexplate for a 1pc rear main seal...then plus the cost of clearancing the block.
Old May 12, 2006 | 07:08 PM
mw66nova's Avatar
Engine: 7.0L
do you think i could get away without doing the notches, and run faster than my previous bests?
Old May 12, 2006 | 07:18 PM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
I know that the TPI 305 guys switch to stock aluminum L98 heads from stock 081/416s all the time. Yours being worked should show even more of a gain. Combine that with the hotter solid cam and you are getting somewhere. I don't recall of a single one, not improving their times.
I know that this is only computer modeling, but my old 305s dyno numbers (converted to FWHP from RWHP) plugged into a stock weight, fully optioned RS camaro showed to give low 13s with 3.23 gears, 700r4, and 2,800 stall. The numbers are farther up in the post.
0060' = 02.14
Now imagine that same engine in your lightweight camaro.
EDIT- The DD2000 numbers are with stock L98 aluminum head flow numbers from Chevy High Performance.
PS-I made a mistake entering numbers on the first chart.
Old May 12, 2006 | 07:40 PM
mw66nova's Avatar
Engine: 7.0L
would you mind running my combo through your dd2003?
race weight with me in it is 3260lbs.
4000stall 10" ati converter, 700r4
3.73 posi, 275/60/15 m/t et street radials, traction is not an issue.
holley 750 double pumper
holley street dominator intake
cam and heads i posted above with c/r i posted above
hedman longtube headers 1 5/8" x 3" with dual 2.5" pipes.
Old May 12, 2006 | 08:01 PM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
This is worst case scenario given that I am using STOCK 113 flow numbers. It should be better with you worked over heads, how much better is unknown without flow numbers. It would be cool to find out how close these numbers really are on your combo. On mine they were damn near what I actually ran.
Not that I am assuming a few things with this, first are all the constants. 65 degrees farenheit, 29.38 in/hg barometer, 55% humidity, 5,800 rpm redline shift points.
0060' = 01.97s @ 37.23 mph
0660' = 08.48 @ 84.27 mph
1320' = 13.12 @ 105.3 mph
Keep in mind that I modeled using STOCK 113s as I could not find a reliable source for ported 113 flow numbers (they are all way different).
Old May 12, 2006 | 08:10 PM
mw66nova's Avatar
Engine: 7.0L
hmm...best 60' with old combo was a 1.75...is there a way you could plug that in? cause it should run way better than that to the 60'.
i believe the mph may be pretty close, i'm expecting 106ish mph...which with a properly setup car is good for 12.6 or 12.7
Old May 12, 2006 | 08:19 PM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
I played with the Launch RPM and the coeffiecient of friction, even bumping it form 1.00-1.50 trying to model slicks, it only helped a little. Modeled tons of wheelspin.
Old May 12, 2006 | 08:25 PM
  #42
mw66nova's Avatar
Engine: 7.0L
i keep thinking that it's 1 tenth drop in the 60' is worth 2 tenths on the big end...that right there would imply a 12.7 pass...so i suppose i'm right on track.
Old May 12, 2006 | 09:18 PM
  #43
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
I am thinking that I have heard the same rule of thumb somewhere too. Puts you close to my initial guess of high-mid 12s.
Old May 12, 2006 | 10:06 PM
  #44
mw66nova's Avatar
Engine: 7.0L
excellent!
Old May 12, 2006 | 10:19 PM
  #45
r0nin89's Avatar
Car: 1987 Chevy Stepside
Engine: 350 TBI w/ a Cam
Transmission: 3 Speed Stick w/ granny low
Agreed. Anyone who cant get power out of a LO3 simply cannot tune the chips properly. Not to mention a mid 13sec N/A car that gets 18mpg and is driven everyday sound pretty good to me... Hell $800 dollars for a big open element into a cowl that feeds it fresh air and hookers headers 3inch all the way out gives you around 230-240hp. Thats just bolt on... throw in a $200 cam $800 Heads and your well near 300hp. Then TBI porting, spacer, Intake manifold larger injectors and fuel pumps and a good chip tune from a knowedgable person and your hittin 300hp
Old May 12, 2006 | 10:22 PM
  #46
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
You are not going to be hitting 230-240 HP without chip tuning and increased fuel delivery. The most HP I have ever gotten out of a 305 with the STOCK chip is 193 RWHP.
Old May 13, 2006 | 12:21 PM
  #47
sasser43's Avatar
Car: 89 GTA
Engine: 350 TPI L98
Yea the rule for 1 tenth in the 60 is 2 tenths in the total ET works fairly acurate.
pjsparts
Oct 29, 2025 06:39 PM
db057
Apr 28, 2019 07:45 AM
383cam
Sep 9, 2015 06:01 AM
rsrookie
Sep 5, 2015 07:08 PM
Formula_88AE
Sep 3, 2015 01:47 PM
