Anyone know anything about cars? Noone's willing to help.....
Old Apr 10, 2006 | 04:42 PM
FBoDyV85's Avatar
Car: 89 IROCZ Camaro
Engine: 350 w/ Boltons
Sorry for the repost but I really need help..
I have a new jasper reman that recently started making a noise. Sounds like a top end chatter type of noise. Kinda hard to explain. I brought it to a local shop thinking it was an engine valve problem of some sort. He had diagnosed the car with a faulty FPR. I then took the car home and bought a new Holley adjustable FPR 35-65lb. I installed it on the car and started it up. The same noise is there. I put a fuel pressure tester on it and the needle is jumping within 2lb's. With KOEO i can adjust it to 44 lbs without a problem. And the MAX pressure i can adjust to is 42-44lbs. I tried pulling injectors 1 by 1 to see if the noise goes away but it does not. The sound seems to be leaning on the driver side portion of the fuel system.
Does anyone have some suggestions on what to look at? Or little quick tests to rule some things out?
-Steve-
(New Issue Update Scroll Down a little)
Old Apr 10, 2006 | 04:49 PM
Token's Avatar
Car: 1992 Firebird
Engine: forged 357
Transmission: 700r4, 2200-2400 stall, vette servo
Axle/Gears: stock pegleg 2.73 drum (temp)
I've never heard low fuel pressure make a chattering noise. Try tightening up the valve lash a tad. It's possible that you have a dead lifter, or a bent pushrod. Also, if you've got a non-roller block (pre-87) you very well could have valvetrain damage in the form of a wiped lobe. Your thread(s) are kinda vague.
Old Apr 10, 2006 | 04:55 PM
FBoDyV85's Avatar
Yea the shop i took it too which is prefered by jasper, said it has to be a fuel issue. He had diag. it as a "Faulty fuel pressure regulator". It sounds like a chattering topend to me. I have no idea how this noise could be a fuel issue. But why would my fuel pressure bounce/jump like it does? What would make that happen?
Old Apr 10, 2006 | 04:56 PM
Token's Avatar
Car: 1992 Firebird
Engine: forged 357
do you have a mechanical fuel pump?
Old Apr 10, 2006 | 05:24 PM
FBoDyV85's Avatar
new news. I started up the car just now and heard the chatter noise i been talking about. When i disconnected the back driverside spark plug wire the *noise* went away. Any ideas or possiblities now?
Old Apr 11, 2006 | 01:09 PM
D's89IROCZ's Avatar
Car: 1989 IROC-Z
Engine: 5.7L EFI LTR setup
Transmission: T-5 World Class
Yeah , you have a wire grounding out . The chatter sound like spark . Just based on that I would get a new set of wires. what do you mean the NICE went away ?
I could be wrong though
Old Apr 11, 2006 | 01:55 PM
FBoDyV85's Avatar
Yea im checked the wire which is new so it was OK. going to replace it anyways just to be on the safer side. its a pain in the @$$ to check but mabye for some reason the spark plug loosened up and the noise is because its not sealed properly. Going to buy a wrench to try and get at it. Hooker headers are a pain to get around. Thanks for the help ill keep you updated.
Old Apr 12, 2006 | 10:19 AM
mean57's Avatar
Car: 87 gta
"Hooker headers are a pain to get around."
you are crazy i can change out the plugs with my longtubes on inside of 20 minutes, try stock manifolds lol.
Old Apr 12, 2006 | 10:34 PM
FBoDyV85's Avatar
easy.. ended up being loose header bolts... weird huh =)
Old Apr 13, 2006 | 08:25 AM
mean57's Avatar
Car: 87 gta
ahh anything can happen. headers coming loose = common
just glad to hear it's fixed.
Frozer!!!
Jan 19, 2024 04:55 PM
Reddeath210
Oct 6, 2015 08:20 AM
Linson
Aug 21, 2015 02:12 PM
kyleb24
Aug 15, 2015 08:24 AM
bryan623
Aug 10, 2015 11:33 AM
