Do I need my Alternator Braket?
Old Apr 14, 2006 | 10:21 AM
Crusin' 1980's's Avatar
Car: 1988 SC Camaro
Engine: 305 TBI
Transmission: 700-R4
I hope not because i cut it off...but does this bracket (that runs from the back of the alternator to the exhaust manafold) really do anything?...is it necessary to have? As you know, the Alternator is supported by (3) bolts that scre into the fron side of the mounting bracket....these bolt are more than enough to support the alternator even under heavy tension from the belt...
[IMG][/IMG]
Old Apr 14, 2006 | 11:35 PM
quisterio's Avatar
Car: 87' GTA
Engine: 350 L98 TPI
Axle/Gears: 3.27 9-Bolt
Yes, my AC has a brace just like that, a little longer, it attaches to the manifolds, but I started to notice the AC shakes REAL bad without it, now im stuck going to the junkyard to find it.
You do need it, because ive been told my AC Bracket will break if I dont find the right brace for it, and your alternator will shake just as bad without the brace for support.
Old Apr 15, 2006 | 06:20 AM
thirdgen88's Avatar
Car: 1995 Corvette
Transmission: 6 spd Manual
Axle/Gears: Dana 44, 3:45:1
And if you have a higher output CS144 alternator, you can actually have the alternator break off its mounts and fall off.. I'd put the brace back on, though its not as critical with a CS130 as is pictured.
RS Reaper
Oct 17, 2018 07:52 PM
apie2546
Oct 16, 2016 02:24 PM
SRKLEGIN
Oct 3, 2015 10:11 PM
RS Reaper
Sep 27, 2015 07:04 PM
raymondandretti
Sep 27, 2015 06:43 PM
