valve lash
Old Apr 25, 2006 | 09:03 PM
88 IROC CONVERT's Avatar
Car: 2002 zr2 Blazer 88 Iroc convertable
Engine: 305 T.P.I.
valve lash
stock 305 tpi, can you do the valves with car running? back off till clicking starts tighten slowly till quiet + 3/4 turn?
Old Apr 25, 2006 | 09:09 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
Correct. Adjust them running. Its the best way. Some people go 1/4 turn, some half, some 3/4 and some full turn. You will be ok on any of them.
Old Apr 25, 2006 | 09:13 PM
JFROG's Avatar
Car: 84 berlinetta
Transmission: auto
how do u keep from getting oil all over the place?
Old Apr 25, 2006 | 09:22 PM
Engine: 305 T.P.I.
they sell clips or put cardboard into bottom of the head so it hits and runs down
thanks for info mkos1980
Old Apr 25, 2006 | 09:25 PM
skid305's Avatar
Car: '89 Bastard RS
Engine: 310 TBI
Transmission: 700 R4
Axle/Gears: 3.23 Posi
check this out: Valve Adjustment Procedure
Old Apr 25, 2006 | 11:00 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Oil just drips out of the holes. Doesnt spray unless you rev it. I've never had oil outside of the motor while doing it this way. The dry procedure is the hard and long way.
Old May 3, 2006 | 03:02 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Note to members:
The contents of the linked site were copied onto this thread. Although there is no problem referencing a link, please do not post copyrighted material to the Board.
Thank you.
Old May 3, 2006 | 06:17 PM
toooldforaz's Avatar
Car: 85 z28
Engine: lg4
Transmission: 700r
Just for the record my GM service manual tells you to do it with the engine off and 1 turn of adjustment. My understanding of the hydraulic lifter is that when the cam is at maximum lift the plunger in the lifter is just bottoming in it's bore and as the lobe falls away oil pressure keeps the lifter in contact with the cam, so if you only tighten the lock nut a quarter of a turn you will not get all the lift from your cam.
SPEEDY Z28
Brakes
16
Apr 18, 2016 02:46 PM
sleprock
Sep 24, 2015 04:33 PM
355tpipickup
Sep 13, 2015 11:35 PM
sandman92084
Sep 12, 2015 10:27 PM
dimented24x7
Sep 6, 2015 03:51 PM
