what do I have? 383? some questions!
Old May 1, 2006 | 08:13 PM
Wishmaster's87IROC's Avatar
Car: 1987 1SICIROC.....1999 TransAm
Engine: 385 HSR.....LS1
Transmission: 700R4 with Midwest 3400 2.4str...M6
Axle/Gears: SLP Zexel Posi unit 3.42's...3.73's
ok..I took the oil pan off today cause I have to change it I think and I have to change the time gears thats that in the motor. but since I got it off I would like to see if any can tell whats in it just from looking a the pictures....I dont know what Im looking for.....I can tell the motor has been machined for the extra clearance though...
here's some pictures...Im pretty sure that you really cant tell what is what just from looking at the pictures but I figured I would give it a shot...
Attached Thumbnails what do I have? 383? some questions!-dsc01826.jpg   what do I have? 383? some questions!-dsc01829.jpg   what do I have? 383? some questions!-dsc01830.jpg
Old May 1, 2006 | 08:17 PM
also ..can I use the oil pan that was on it? it was suppose to be for a 87 corvette but Im sure it wont work for an 87 camaro....the oil pump and pan is suppose to be extra capacity...but will it fit?..if not what can of pan do I need to get?or will I also have to change the oil pump...it goes deep in the oil pan..
Attached Thumbnails what do I have? 383? some questions!-dsc01832.jpg   what do I have? 383? some questions!-dsc01831.jpg   what do I have? 383? some questions!-dsc01828.jpg
Old May 1, 2006 | 08:29 PM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
looks like the pan will fit to me. i think the only pans that don't fit are the truck style pans. the motor looks like it's a 4 bolt main with nice rod bolts, but no idea if it's a 383 or 350, measure the stroke with a ruler to find out for sure
Old May 1, 2006 | 08:33 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
Rotate the crank around a few times and try to look for a casting number somewhere on it.
Old May 1, 2006 | 08:39 PM
Looks a little like a stock 400 crank to me... cast... I see the "flat cut" on the top of the counterweights, for 5.565" rods.... is it a 511 casting?
Old May 1, 2006 | 08:42 PM
its suppose to have 6" rods...
Old May 1, 2006 | 08:46 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
That might be what it has now, but if it was a stock 400 crank it was made for 5.565" rods.
Old May 1, 2006 | 08:57 PM
cut& polished steel crank, forged 6" rods clevite brgs. attached to .30 over flat top piston
thats what I was told....any way to tell?
Old May 1, 2006 | 09:27 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
The pan rails seem virgin and untouched.
Old May 1, 2006 | 09:29 PM
xpndbl3's Avatar
Car: 1984 Z28
measure top of stroke and bottom of stroke to tell if it's a stroker crank
Old May 1, 2006 | 11:27 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
It's hard to tell from that pic, but there are a couple of spots that look to me like they've been touched a little.
Old May 1, 2006 | 11:34 PM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Transmission: TH-350C
Axle/Gears: 3.43
definately looks like it had some work done there...
Old May 2, 2006 | 06:02 AM
its suppose to
whats in it
2 different things
Get some numbers off of it
Old May 2, 2006 | 12:02 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
not related but whats up with the motor mounts in the 1st pic?
Old May 2, 2006 | 07:36 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Y bodies don't do things the usual way.
Old May 2, 2006 | 09:45 PM
the motor mount are for a vette...I need to change them...right?
Old May 2, 2006 | 09:49 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Yes, you'll need the clamshell brackets from a thirdgen V8.
Cameeeero
Sep 18, 2015 04:00 PM
Mickeyruder
Sep 2, 2015 02:45 PM
gixxer92
Sep 1, 2015 04:32 PM
lt1z350
Aug 28, 2015 05:57 AM
redmaroz
Aug 16, 2015 11:40 PM
