Problem.
Problem.
I have a problem. I gave it a bit of gas and something in my driveline made a bad snapping sound. The car ran but made grinding sounds periodically. I shut the car off maybe 10 seconds after the sound happened. The car will not start. The starter turns the flywheel and the torque converter, but the crankshaft will not turn(the belt does not spin.) Any ideas on what this could be?
PS: I didnt know if this was a transmission or an engine problem, so it may be in the wrong forum.
Car: 84 Z28
Engine: 357
Transmission: TH-350C
Axle/Gears: 3.43
So the starter is turning...
Are you 100% sure the flexplate is turning? Starter could just be spinning and not engaging...
If the starter IS actually engaging and turning the flexplate then you either lost all the bolts that hold the flexplate to the crank, or you snapped the crank...
Car: 92 B4C/1LE CHP camaro 06 vette LS2,
Transmission: iroc, 700r4, auto
i actually had a cam break in half several years ago. pull the distributor cap, crank it and see if it moves.
sounds like either a cam or crank broke.
Sounds alot like the center broke out of your flex plate.
Pretty common. Although most people quit driving the car when it starts makingall the racket that it always makes, and it doesn't usually get as far as breaking all the way out.
Not a big deal in any case. Just replace the flex plate.
Car: 84 Z28
Engine: 357
Axle/Gears: 3.43
True enough, my dads 305 truck had a crack around the bolts about 320* around. The truck had a nasty vibration at high RPMs and we couldnt figure out for the life of us what the problem was till we pulled them motor for a swap (the old 305 was tired...) and noticed the HUGE crack in the flexplate!
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
OUCH!
oh well, of the problems listed in this thread, that's the cheapest and easiest to fix so it looks like you got lucky...
Car: 84 Z28
Engine: 357
Axle/Gears: 3.43
Definately got lucky!
under $50ca to get a OE flexplate up here so its one of the cheaper fixes you will have to do. Other than the PITA its going to be changing it!
HoosierinWA
Oct 7, 2015 10:15 AM
