92 camaro rs stalling
Old May 6, 2006 | 02:40 AM
shaggie1's Avatar
Car: 92 Camaro RS
Engine: 305 for now
HI I new to the board and this is my first camaro I have a 92 camaro rs 305 tbi idles ruff and dies at a stop acts like flooding boggs down when give it gas
i have replaced the air filter fuel filter and pcv valve ant the coolant temp sensor same prob
i can unplug the tps the map and the coolant temp sensor and it runs fine
i can plug up the coolant sensor and the tps and and the idol is fine when i plug up the map it starts surging and dies after it runs for about 10 to 15 min i can drive it but if i have to come to a complete stop it stalls after i drive it a few miles sometimes it will run ok others it keeps stalling
Old May 6, 2006 | 12:52 PM
kjvail1204's Avatar
sounds like its a bad MAP sensor, i mean if its unpluged and runs fine then you plug it in and it dies it would tell me that its the MAP
Old May 6, 2006 | 03:02 PM
shaggie1's Avatar
Car: 92 Camaro RS
Engine: 305 for now
ok thanks i have a new one on the way
ill keep posted
Old May 27, 2006 | 12:59 AM
shaggie1's Avatar
Car: 92 Camaro RS
Engine: 305 for now
OK replaced the map still same prob except wont run with the tps plugged in plug it up and stalls and as long as i have the vac line to the map and the tps unplugged run good can drive it some cant give a lot of gas at a time do to it starts backfiring
Old May 29, 2006 | 05:35 PM
bonacci1's Avatar
Car: Lumina Z34
Engine: 3.4 Twin Dual Cams
Transmission: 460TE
Stalling still????????
We replaced the IAC on my sons 92 TBI 305.
Now his coolant fan and the blower for inside the car doesn't work. Taking car to the dealer tomorrow to figure this one out.
Old Jun 2, 2006 | 01:23 PM
PoppaCon's Avatar
Car: '92 Camaro RS
Engine: 3.1L
Transmission: Manual
I am having the exact same problem and suspect the throttle position sensor. I only have problems on warm afternoons, however. My local mechanic wasn't able to diagnose the problem. Please let me know what you find!
Old Jun 7, 2006 | 10:39 PM
Chriznoznae1's Avatar
Car: 91 camaro z28
Engine: L98 350, Vortech heads, Lt4 cam
Axle/Gears: 9 bolt 3.27
Had the Same problem
Well i had the same problem and i swear it was like a phantom problem. The car would run fine for a while then die when i hit the gas. I replaced every sensor in the car, the prom chip, the computer itself, i mean everything. finally i sent the car to a mechanic and it was the wires that connect to the coolant tempature sensor. If they are bad or are shorting out they cause the injectors of the car to go pig rich.
If the sensor was totally shorted or disconnected it would show up on the check engine light. But in my situation the sensor was working but was telling the computer that my car was in negative 33 degree weather causing the car to go super rich.
All the super camaro freaks out there say that can't be causing the injectors to do that but after the wires were fixed my car was purring nice.
Oh i forgot to mention, my car would only do it on hot days at first also. it got worse over a week or two time frame
Old Jun 8, 2006 | 04:43 PM
shaggie1's Avatar
Car: 92 Camaro RS
Engine: 305 for now
thanks ill ck the wires I did not think of that
now it don't want to stay running at all but it is getting low on gas
but ill go ck wires tonight when it cools down its above 100 here to hot with no shade
Old Jun 8, 2006 | 06:58 PM
shaggie1's Avatar
Car: 92 Camaro RS
Engine: 305 for now
ok i have found a wire that has pulled out of the connector on the passenger side below exhaust manifold any ideas what could be to
Old Jun 8, 2006 | 10:03 PM
Car: 91 camaro z28
Pulled wire
Well i have a 91 Z28 and the O2 sensor is on the driver side so i have no idea
Old Jun 8, 2006 | 10:33 PM
regan8robin's Avatar
That could be the cooling fan switch. I had some problems with that one.
Old Jun 9, 2006 | 02:20 AM
shaggie1's Avatar
Car: 92 Camaro RS
Engine: 305 for now
i am about ready to swap to carb and do away with the electronics
i have had this car for 5 months now and have drove it less than 200 miles
it ran great for the first 2 weeks then went to having a small prob but could drive it now wont stay running
Old Jun 19, 2006 | 07:32 AM
Petrovich's Avatar
Car: Chevy Camaro RS 1992
Engine: 3.1 L
Transmission: Automatic
As far as I can see in this forum this is VERY common problem for v6 and other engines when you ride at 20-40 km/h and engine dies despite of smooth idle at park. With my car I had the same for a pretty long time. Now the problem is resolved.
Here is the procedure.
Conditions:
1) correct spark advance
2) no ignition problems (good plugs, wires and distributor)
3) no big vacuum leaks
4) good IAC
Now to do:
1) screw out throttle adjustment bolt untill throttle is completely closed
2) turn on ignition and wait 5 sec.
3) disconnect IAC plug
4) run the engine
5) turn throttle adjustment bolt untill engine revvs up suddenly (you need to find this threshold) and add 1/2 turns more
6) shut off engine
7) connect IAC
8) disconnect negative battery cable to reset ECM
9) connect battery
10) run engine
That's all.
Peter, Moscow, Russia
p.s. the problem was in incorrect throttle adjustment.
Old Jun 21, 2006 | 02:22 AM
shaggie1's Avatar
Car: 92 Camaro RS
Engine: 305 for now
i got to cking vac lines and had 2 disentagrate in my hand so gotta replace them before ant more trouble shooting can be dune
Old Jun 21, 2006 | 11:47 PM
jstrdn90rs's Avatar
Car: 90 RS/90 Z-71/73 Vega
Engine: 3.1/5.7 TBI/5.7
Transmission: 700R4/700R4/350turbo
Axle/Gears: 3.23/3.42/3.42
90-92 v6 camaros hate vacuum leaks..check the brake booster,the fuel pressure regulator,and the divertor valve.My car died at every light and my booster was junk..I played/replaced with every sensor with no change.The fuel regulator and divertor valve are tied together by those cheap plastic lines that everybody touches and it breaks.If you have no check engine light I would say you have a vacuum leak.
Old Jun 24, 2006 | 01:22 AM
shaggie1's Avatar
Car: 92 Camaro RS
Engine: 305 for now
the car will now idle OK with the vac line to the map sensor and the tps unplugged if you plug up the vac line the rpm will go up and down till it dies if you plug up the tps it will rev up and die and you will see gas spit out of the throttle body
gona look for a intake and carb at a wrecking yard
Frozer!!!
Jan 19, 2024 04:55 PM
92camaroJoe
Jul 29, 2023 07:57 PM
jklein337
Sep 19, 2018 06:23 PM
Bryan F
Aug 18, 2015 02:28 PM
92camaroJoe
Aug 13, 2015 06:07 AM
