600hp w/t-tops
Old May 9, 2006 | 07:32 PM
raptor80dad's Avatar
Car: 92rs
Transmission: 350
Axle/Gears: 3.73/Moser 12bolt
600hp w/t-tops
I currently have a t-top camaro and would like to install an engine putting out app. 500 to 600 hp. my question is will the body hold up with just subframe connectors or should i look for a hard top ? hope i posted in right forum.
Old May 9, 2006 | 07:56 PM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
500-600 hp, so you're planning on putting in a cage as well to run in the low 11s high 10s? otherwise try out the subframes, some 4th gens run that much power, but a roll bar wouldn't be a bad idea. i put in a 6 point, not really that bad to get in and out, and with that kind of motor i wouldn't expect daily driver out of it anyways.
Old May 9, 2006 | 08:10 PM
Car: 92rs
Transmission: 350
yeah xpndbl3 i will have to put in a cage as i will be going to the track.
when i posted i did not take that into consideration.just wanted to make sure before i get into it .
Old May 9, 2006 | 08:16 PM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Transmission: TH-350C
Axle/Gears: 3.43
600hp with some sfc's... Can you say "i got glass in my hair!!"
A 'GOOD' pair of weld in SFC's and a STB will definately help to keep the thing from twisting up like a pretzel.
But if your putting in a cage, that is going to strenghten it up pretty darn good and t-tops shouldnt be an issue.
Old May 9, 2006 | 08:19 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
I've never had a problem with my T-tops. I had SFC from the first day I went to the track. A few years later when I was just about to hit 11 seconds, I put in a 6 point roll bar. When I started getting into the 10's I installed a full cage.
Of course my car also isn't street legal and has a lot of interior sheet metal cut out but I've never had a problem with the T-tops. I can still take them out when working on the car to make getting in and out easier even with the full cage.
Old May 11, 2006 | 04:58 PM
Car: 92rs
Transmission: 350
I will be putting weld in sfc's probably spohn's and at least a six point cage by a reputable welder.I like the t-tops so i am going to keep this body for my project after hearing your advice.right now i am running the original 350 and slowly building the chassis and needed to know this for when the 350 goes .
thanks to all for your time!
IROCZ1989
Sep 4, 2015 11:54 AM
Intensity_Z
Apr 14, 2004 01:40 PM
Box of Rocks
Jan 16, 2001 01:28 PM
