LS1er needs TPIer HELP
Old May 10, 2006 | 02:51 PM
popocamaro2's Avatar
My first two cars were an 87 & 89 iroc z both I did minor mods too but this was in the very early 90`s when i was 16 years old and there were not a lot of aftermarket products. Anyways I have a good friend who just got back from iraq and he is looking to restore and beef up his engine. What is the most common & good H/P increasing mods out there for these so I can relay to him what to buy. Thanks
Old May 10, 2006 | 04:39 PM
89RsPower!'s Avatar
Car: 86 Corvette, 89 IROC, 1999 TA
Engine: 350, 350, LS1
Transmission: 700r4, 700r4, T-56
Axle/Gears: 3.07, 373, 4.10
first place to start on these cars is the exhaust system, the whole thing from the manifolds on back.. the factory manifolds are horrible.. Its amazing how a set of headers and a catback will wake these cars up..
Old May 10, 2006 | 05:06 PM
SloCobra's Avatar
Car: bitchin' camaro
Engine: LG4
Is he staying with TPI? A different manifold or larger runners and base and a ported upper plenum would be good. A proper cam always helps on power, even with stock TPI.
Old May 10, 2006 | 06:19 PM
I figured upgraded runners and maybe a throttle body would be good as well as the headers and exhaust but i wanted to see which of these people have had the best of luck with power & $ wise. Also I have heard someone say LT1 cams are great for TPI cars , he wants to be in the 3xx`s RWHP range so I am just gathering as much info as I can to lead him in the right direction thanks for your comments
Old May 10, 2006 | 06:30 PM
superGMman's Avatar
Car: '92 Toyota Pickup
Engine: 22R-E
Transmission: 5sp Manual
Axle/Gears: 4:??
Stock TB is good to 400 hp+ so a new one would be a complete waste of money.
300 RWHP w/ tpi would be expensive. Switching over to a carb or stealthram(high rpm short runner replacement manifold) would make that mark alot easier to get to.
How much money can he spend?
Old May 10, 2006 | 06:45 PM
probably about $3000
Old May 10, 2006 | 07:08 PM
the stealth ram looks intresting but what else would need upgrading/changing and to what when going with that system
Old May 11, 2006 | 06:42 PM
any other advice
Old May 13, 2006 | 10:21 AM
superGMman's Avatar
Engine: 22R-E
Axle/Gears: 4:??
Get stealthram: Thunder Racing - Intake Manifolds & Accessories for your 1982-1992 F-Body. Gonna need the intake manifold and baseplate which is 300$, and the fuel rails down below. Getting the vortec version and some vortec heads would make a big difference.
Get some Hooker shorty headers part no. 2055. If he can afford it, SLP makes 1 3/4 inch primary shorties. Longtubes is an option as well.
Get a nice cam to compliment the stealram's upper RPM power range, call comp cams, I suck at prescribing cams.
