engine question
Old May 14, 2006 | 07:01 PM
jkwild0630's Avatar
Car: 86 camaro z28
Engine: 5.7 carb
engine question
when i turn my wheel it makes a poping sounds, i think its the tie rod end
when pressing the gas, i near a ratting sound from under the car. can someone help
Old May 14, 2006 | 07:08 PM
ScottyRS's Avatar
Car: 1992 Camaro RS
Axle/Gears: Stock
The best thing you can do is get under the car and have someone step on the gas and turn the wheel, then find the noises yourself, to be sure.
Old May 14, 2006 | 07:14 PM
jkwild0630's Avatar
Car: 86 camaro z28
Engine: 5.7 carb
i did that it looks like the tie rod end, and it sound like the excuast ratting
Old May 14, 2006 | 07:36 PM
camaro608's Avatar
the rattle could be the egr tube or the cat
go under thr car and find the egr tube that goes in the cat abd try to move it if it moves clamp it with a clamp for a heater hose or somthing that wont melt like a zip tie
and fotr the popin noise lift the car up and turn the wheel with someone looking at the steering parts
Old May 14, 2006 | 07:39 PM
ScottyRS's Avatar
Car: 1992 Camaro RS
Axle/Gears: Stock
Well then that answers your question.
Old May 14, 2006 | 07:49 PM
jkwild0630's Avatar
Car: 86 camaro z28
Engine: 5.7 carb
i dont have a cat the egr tube where is that under the car
Old May 15, 2006 | 03:37 PM
camaro608's Avatar
well....if you dont have a cat then you probably dont have an egr tube
so...i honestly dont know what to say without seeing the car
Old May 18, 2006 | 09:06 AM
jkwild0630's Avatar
Car: 86 camaro z28
Engine: 5.7 carb
it was the inner and out tie rod end on the passenger side, and the tires were bad causing all the problems
Frozer!!!
Jan 19, 2024 04:55 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
redmaroz
Aug 16, 2015 11:40 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
84z96L31vortec
Aug 10, 2015 08:27 PM
