SOLVE THIS ONE!!
Old May 16, 2006 | 04:57 PM
87gtaJOLENE's Avatar
Car: 1987 gta T/A
Engine: 5.0 TPI
Axle/Gears: 3:23
SOLVE THIS ONE!!
This has been happening for 2 years now. I would start my car and it would rumble like if It had a huge cam. Then after about 2-3 seconds the rpms would finally sit where they are supposed to and the car would run and sound fine. And sometimes, the car would make the "big cam" noise and then shut off completley. Then I would have to turn the key 3-4 times to get the car running. All my ignition components have been changed, alternator and battery are brand new. Fuel pump relay? Fuel pressure regulator? please helllp!
Old May 16, 2006 | 05:01 PM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Transmission: TH-350C
Axle/Gears: 3.43
Does it puff a bit of blue on startup?
possibly getting oil in the cyls and fouling the plugs for a bit till it burns out.
Old May 16, 2006 | 05:05 PM
Car: 1987 gta T/A
Engine: 5.0 TPI
Axle/Gears: 3:23
yeah I get a huge puff half the times i start my car... how coudl that be fixed?
Old May 16, 2006 | 05:26 PM
iroctj's Avatar
Car: 86 IROC-Z
Engine: 385 TPI
Transmission: 700-R4
Axle/Gears: 9Bolt 345'S
u have a bad IAC motor or its plugged up
Old May 16, 2006 | 05:37 PM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Axle/Gears: 3.43
^^ could also be a sticky IAC...
But that depends if the smoke could was actually blue (oil) or black (too much gas)
If its blue your valve seals are most likely the culprit unless it also smokes when its warmed up which would be rings.
nelapse's Avatar
Car: GTA
Engine: 383 HSR
Transmission: TH-700R4
Sounds like valve stem seals to me... atleast that is prolly why you smoke only on startup.
nelapse's Avatar
Car: GTA
Engine: 383 HSR
dang you answered same time as me
Old May 16, 2006 | 06:28 PM
Car: 1987 gta T/A
Engine: 5.0 TPI
Axle/Gears: 3:23
its a blue smoke. could be the valve seals... or a IAC motor? What's an IAC motor?
Old May 16, 2006 | 07:57 PM
Car: 1987 gta T/A
Engine: 5.0 TPI
Axle/Gears: 3:23
Nevermind, i did my homework haha. I'll clean or replace the IAC motor and see if thats it. you guys are the ****
Pac J
May 17, 2020 10:44 AM
tyeo098
Nov 30, 2015 06:27 PM
Giocio
Oct 1, 2015 12:20 PM
db057
Sep 4, 2015 07:57 AM
CORV3TT3
Aug 23, 2015 11:26 AM
