396 engine help
Old May 17, 2006 | 03:07 AM
396V8's Avatar
Car: 1990 Corvette
Engine: 415
Transmission: six speed
Axle/Gears: Dana44 3.73
396 engine help
Hi!!
I built a 396ci engine, topped with AFR 210comp.port heads, and Accel single plane EFI and a 224/230 605/622 comp cam.
Throttle body is an 58mm….
My problem is..i have no power…about 340chp and 360ctq..why?
I think, my cam is maybe too small…
The problem is, I live in Austria, and I cannot drive with an extreme idle..
My current cam have an overlap of 52°, if I change to a 236/236 XFI series cam, it will be 62°
Or should I go with a bigmouth intake and siamesed SLP runners?
Thanks for answers
Old May 17, 2006 | 07:57 AM
What pistons did you use? What is the deck clearance? (looking for the numbers to ACCURATELY determine your compression)
What tuning has been done to it?
What are the total HP vs RPM and torque vs RPM curves like?
If you mean "crankshaft HP" by chp, then there's definitely something wrong. It's not the cam. You should be getting AT LEAST 75-100 HP and torque more than what you have.
Are you certain that the throttles are opening all the way?
Old May 17, 2006 | 08:27 AM
396V8's Avatar
Car: 1990 Corvette
Engine: 415
i use forged JE pistons with 5cc Valve reliefs..clearance is 0.035..oh sorry, didnt mention....static compression is 10.46 to 1 , dynamic 8.2 to 1, heads have a 72cc chamber
total hp is 340 CRANK ant 5500, torque is 360 at 3850
throttle is open all the way, surely
i know, theres something wrong..and i think, its the part combination..the cam doesnt like the single plane very much and vice versa
Old May 22, 2006 | 01:02 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
Axle/Gears: Stock IRS
hp seems a bit low to peak at that rpm, what do u run for exhaust?
Old May 22, 2006 | 01:08 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
Has the engine been given a proper tune?
Old May 23, 2006 | 12:34 AM
396V8's Avatar
Car: 1990 Corvette
Engine: 415
Hi all
i use TPIS LT headers, free flowing exhaust, with just Flowmaster mufflers..
The tune of the engine i would say is perfect...A/F ratio, timing, everything perfect..takes throttle smooth, no hickups, nothing
just lacking power...
Old May 23, 2006 | 01:37 AM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
not sure about engine dynos, maybe it had some wrong input? is the engine in a car yet?
Old May 23, 2006 | 01:44 AM
396V8's Avatar
Car: 1990 Corvette
Engine: 415
Hi
yes, the engine is still in the car...anyways, i will step up to a Lunati cam 234/238 and also add a divider plate to the single plane
hope this helps..
im just really clueless, what could be faulty...
84z96L31vortec
Aug 20, 2017 12:16 AM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
Reddeath210
Oct 6, 2015 08:20 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
