How high compression are you running on 92 octane gas?
Old May 17, 2006 | 08:46 AM
Johnny Blaze's Avatar
Car: 1971 Camaro
Engine: 427
Transmission: TKO600
Just as it says.
Old May 17, 2006 | 11:47 AM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
10:1 on iron heads, ~.055" quench, polished head chambers, smoothed piston tops, 4000' altitude, will have 36* WOT timing. 227/234 hydraulic flat tappet cam, with 1.6 rockers. 8:1 dynamic CR IIRC. 91 octane so far.
Old May 17, 2006 | 12:46 PM
rx7speed's Avatar
Car: 2005 BMW 545i
Engine: 4.4L N62B44
Transmission: 6spd auto
Axle/Gears: Rotating
I run 8:1
Old May 17, 2006 | 12:53 PM
Sonix's Avatar
Car: 1982 Trans-Am
I run 8:1
...in a completely non relevant application...
Old May 17, 2006 | 01:08 PM
Car: 1971 Camaro
Engine: 427
I had a couple wankles, but what does it have to do with 3rd gens?
Old May 17, 2006 | 03:48 PM
gpbtt's Avatar
Car: 1991 Camaro RS
Engine: 383 stroker
Axle/Gears: 3:73 Eaton limited slip
We run10:5 on our 383.........Street driven.
Old May 17, 2006 | 03:55 PM
Trevor86TA's Avatar
Car: 86 Trans Am
Engine: 406
Transmission: TH350, 4200
Axle/Gears: Moser 9", 3.89
11:1 on 91 octane with a 236/242, 108 solid roller in a 406 with aluminum heads.
Old May 17, 2006 | 04:12 PM
rx7speed's Avatar
Car: 2005 BMW 545i
Engine: 4.4L N62B44
nothing but neither does the 8:1 compression
Old May 17, 2006 | 04:49 PM
CreepingDeath94's Avatar
Car: '87 Trans-Am
Engine: LB9 (305 TPI)
Axle/Gears: 3.42 or 3.73..figuring it out still
I'm probably around 10.5 to 11:1 on 92
Old May 17, 2006 | 09:33 PM
1989GTATransAm's Avatar
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
The question should read "how much dynamic compression to you run on 92 octane?" I plan on running 8.50 dcr with a .035 quench, aluminum heads and 91 octane.
Old May 17, 2006 | 10:20 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
10.6-ish with cast iron heads, flat tops, and a 230/236 cam. Its around 8.5 DCR.
I use 91 in the motor.
Old May 18, 2006 | 09:13 AM
Dialed_In's Avatar
Car: '88 IROC-Z medium orange metallic
I've got 10.5 in mine but with the new fuel standards I had to pull a few degrees of timing out from all the damn water in the gas and the slower burn rate of the alcohol. I run a 85/15% mix of pump 93 and VP red when I go to the track.
Old May 19, 2006 | 11:49 AM
SScott's Avatar
Car: 91 Mustang
Engine: 306
Axle/Gears: 8.8 4.10's
I know you are asking in present-tense but I sure hope I can get away with 11.5:1 w/ Iron heads on a 396.
Old May 19, 2006 | 12:02 PM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Transmission: TH-350C
Axle/Gears: 3.43
My new engine will be around 9.5:1 and will be running 91.
355ci
416 heads, barely touched
Xe268 cam
Hopefully it doesnt go boom
Old May 19, 2006 | 12:14 PM
flrtin1's Avatar
Car: Z/28..39 Plymouth truck in progress
Engine: S/B
Transmission: Manual
Around 12.1:1 effective on 93 octane.
Old May 19, 2006 | 05:56 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
10:4:1 with 89
Old May 19, 2006 | 06:33 PM
Car: 1971 Camaro
Engine: 427
Please share the details on how.
Old May 19, 2006 | 06:36 PM
flrtin1's Avatar
Engine: S/B
Roots Blower
customblackbird
Aug 15, 2021 10:16 PM
bryan623
Mar 22, 2021 06:43 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
355tpipickup
Aug 13, 2015 07:35 AM
BBSDesigns
Aug 11, 2015 07:39 PM
