How far away from 400hp am I?
Old May 19, 2006 | 06:53 PM
Token's Avatar
Car: 1992 Firebird
Engine: forged 357
Transmission: 700r4, 2200-2400 stall, vette servo
Axle/Gears: stock pegleg 2.73 drum (temp)
I finished porting my Vortec heads. I cut out all of that excess material on the exhaust side, cleaned up the casting marks on the intake side, and gasket matched em all. I also unshrouded everything, contoured the guides, gave them a 3-angle valve job, and hot tanked them. Reassembling them with tri-coil valve springs (properly shimmed), undercut stainless steel valves, screw-in studs, guide plates, hardened pushrods, and 1.6" roller rockers.
They will be topping a 4-bolt Chevy 350 bored .040" fully forged with ~9.5:1 compression. My cam currently is a cc305 (220/230, .544/.544", 112) and I have a full exhaust 3" all the way back (electric cutout for races). My intake is an Edelbrock RPM Air Gap manifold, the dual-plane style with the notch out of the center. I currently run an Edelbrock 1406 600cfm carb.
What's left for 400hp?
Old May 19, 2006 | 09:02 PM
86camaro383's Avatar
Car: 86 Iroc
Engine: 383
Transmission: TH350
Axle/Gears: 3:73s!
Whats the CCS of your heads?
Old May 19, 2006 | 09:43 PM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
cam is larger than needed for 400 hp. a comp XE274 should be good for 400 hp with a performer RPM air-gap intake and a 750 double pumper carb, not a crap edelbrock 600. so the motor should make more than 400 with a real carb on top instead of that thing.
Old May 19, 2006 | 09:48 PM
Nixon1's Avatar
Car: 95 E-150 & 07 Kawasaki ZX-6R
Engine: A slow one & a fast one
Transmission: A bad one & a good one
Axle/Gears: A weak one & a chained one
Agreed his Edel 600 is junk.....I hate edelbrock carbs....but do you think a 750DP is gonna be streetable? Sounds like he's got a pretty street-friendly combination for the most part..... I dont know much about what you can get away with on a 350, but I know on a 302, you CAN pull off a 650DP, but the streetability pretty much sucks. Just thought I'd mention that.
But I do agree, bout anything would probably be better than a 600 Edelbrock, Im just questioning whether perhaps a 650DP might be better for his combination. I guess it depends on what his plans are for the car
Old May 20, 2006 | 08:51 AM
Token's Avatar
Car: 1992 Firebird
Engine: forged 357
daily driver in summer
Old May 20, 2006 | 09:10 AM
Nixon1's Avatar
Well I can tell you from experience that running a wild combination on the street is cool for a day or two but it gets real old after that. Keep that in mind...it's always better to go slightly conservative, than full-bore and wind up perhaps overcarbed/overcammed for what you're intending to do.
Old May 20, 2006 | 10:20 AM
85z28guy's Avatar
Car: 85' Z28
Engine: 383 roller
Axle/Gears: Ford 9" 3.70
No way a 750dp will over carb that engine. I do however agree that it may be a little over cammed.
Old May 20, 2006 | 10:33 AM
gmgod's Avatar
Car: 92 T/A VERT
Engine: LB9
Transmission: AUTO
Axle/Gears: 7.5 / 3.42's
How is a 220/230 on a 112 lsa overcammed?
Old May 20, 2006 | 12:11 PM
acidpad's Avatar
Car: 1991 RS
Engine: 406 in progress
Transmission: th350
On a daily street driver, I think that I would look more toward a 670 holley street avenger than a full on double pumper. The vacuum secondaries will give you the drivability you want, and the performance when you need it.
Old May 20, 2006 | 06:00 PM
EvilCartman's Avatar
Car: '82 Z28
pfffffff That carb is junk. If a double pumper is so bad, how come I still got 22 mpg highway with a 750 on my old 305? Isn't that about the same as the stock quadrajet? A double pumper is fine for daily driving, you drive on 2 barrels just like a vacuum secondary carb. Only difference being when you put your foot into it. You could drive a 400 hp engine around town with all the acceleration you'd need without tipping into the secondaries.
Old May 20, 2006 | 09:37 PM
85z28guy's Avatar
Car: 85' Z28
Engine: 383 roller
Yea I agree. Anyone that says a dp is no good on the street either over carbed, or can't tune worth a damn.
Old May 20, 2006 | 11:23 PM
CamarosRUS's Avatar
Car: 1991 Z28
Engine: 383
Axle/Gears: 3.08 10 Bolt
You should be able to get 400 flywheel hp with that. I wish sometimes I would have went Vortec and saved some damn money...
Old May 21, 2006 | 12:55 AM
Token's Avatar
Car: 1992 Firebird
Engine: forged 357
I drove it for 6000 miles all summer May 05-Oct 05 without ANY issues being over-cammed!
I got a tattoo today...
Old May 21, 2006 | 09:13 AM
eric17422001's Avatar
Car: 3
Engine: inboard
Transmission: underfloor
Here's mine!
Old May 21, 2006 | 01:42 PM
Token's Avatar
Car: 1992 Firebird
Engine: forged 357
such pretty forged pistons!
Old May 21, 2006 | 06:23 PM
yupitsdadsbird's Avatar
Car: 91 RS
Engine: 5.0 tbi
I got the same ones in .030 for my motor
Old May 21, 2006 | 06:24 PM
Token's Avatar
Car: 1992 Firebird
Engine: forged 357
are they pretty sweet?
Old May 21, 2006 | 08:18 PM
85z28guy's Avatar
Car: 85' Z28
Engine: 383 roller
Cool tat! Relax, imho you are a little over cammed for what you have. Guess I didn't see no flow bench results either though
Old May 21, 2006 | 08:53 PM
Token's Avatar
Car: 1992 Firebird
Engine: forged 357
how do you figure over-cammed??
Scorched1984
Wheels and Tires
66
Apr 16, 2016 06:56 PM
abray1
Sep 10, 2015 04:53 PM
makaveli09
Aug 12, 2015 09:07 PM
JayZ28
Sep 6, 2001 08:56 PM
icenine9
Aug 7, 2001 12:20 PM
